Question about Nu Mark Numark Cdn36 Dual CD Player CD Player
Cdn 36 pbm
When I insert a cd into the right side tray it takes long time to register the tracks are simply play. Compaired to the left side which starts playing right away within approx. 3 seconds. Theirs definitely a problem, is there anything I can do.
    Problem Solver:
  • 6 Answers
Unit needs internal cleaning. cleaning cd probably won't work.
Posted on Dec 14, 2008
The tray will not open. I loaded the cd's into the changer, closed the tray and it sounded like one of the cd's may have slipped. It does not change or play.
my friend u r going 2 have 2 take it apart. you will have 2 unscrew 4 or 6 screws from the side or bottem 2 take off the top a take out the cds yourself. its not hard 2 do.just remember tht a disk changer can b off track. its possible 2 pull it open but dnt do it if u will break the door track
May 09, 2011 | Denon DCM-290 5-Disc CD Changer / Player
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
My right side does not play
Hi I have the CD-Mix 1 unit and my left hand disk tray is doing exactly as you describe, i have dismantled the whole thing and tested out and looked at as much as i can and everything seems okay. It's almost like something isn't quite lining up properly when the disk tray is closed because I have found that pulling down the tray door and using my thump to hit the right hand side of the tray itself eventually gets the disk spinning. The main issue is that when you hit the unit so hard the cd playing in the other tray skips as you would probably expect...But at least this information might at least let you spin up one and then fade/mix with the other afterwards.
If you do find out the exact issue, please email me at littleguydan@googlemail.com
Thanks!
Jul 24, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Jvc xlmv33 three tray karaoke cdg player
TRY A LASER LENS CLEANER,,AND TAKE COVER OFF TRY BLOWING IT OUT ,,
May 12, 2009 | JVC KARAOKE, 3-CD CHANGER, 3 MIC INPUT,...
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
PS2 Disk tray wont go in all the way
IF FOR SOME REASON THE TRAY DOES NOT OPEN, OR HALF-WAY OPENS FOLLOW THE FOLLOWING STEPS TO RE ALIGN IT.
STEP 1) TAKE THE COVER OFF, BY UNSCREWING IT FROM THE BOTTOM.
STEP 2) NOW TAKE OFF THE 4 SMALL SCREWS ON TOP OF THE CD ASSEMBLY, ONCE YOU TAKE THEM OFF THE TOP SHOULD COME OFF EASILY.
STEP 3 ) YOU SHOULD BE ABLE TO SEE THE SPINDLE AND THE LASER NOW. BEFORE YOU DO ANYTHING ELSE TURN THE PS2 ON AND HIT THE POWER BUTTON. ONCE YOU HIT THE POWER BUTTON THE SPINDLE SHOULD SPIN AND THE LASER SHOULD MOVE FOWARD AND BACKWARDS AND ALSO UP AND DOWN. IF ALL THIS HAPPENS THEN YOUR PROBLEM PROBABLY IS THE TRAY IF ONE OF THOSE THINGS DON'T MOVE THEN THATS PROBABLY YOUR PROBLEM. NOW HIT THE REST BUTTON AND SEE WHAT HAPPEN
STEP 4) IF THE TRAY IS MISALIGNED, LOOK TOWARDS THE FRONT LEFT SIDE OF THE TRAY YOU WIL SEE TWO SCREWS, TAKE THOSE OFF SO YOU CAN TAKE THE TRAY OFF.
STEP 5) ONCE THE SCREWS ARE OFF, LIFT THAT SIDE AT ABOUT A 45 DEGREE ANGLE AND PUL THE TRAY OUT.
STEP 6) BEFORE WE TRY TO REALIGN IT TURN THE POWER BACK ON AND HIT THE EJECT BUTTON, WE JUST WANT TO PROVE ALL THE GEARS AND THE MOTORS ARE WORKING. IF THEY DO MOVE THEN THE ONLY THING NEEDED IS THE REALIGNMENT. IF THE GEARS DON'T MOVE YOU PROBABALY HAVE A BAD MOTOR OR A GEAR MIGHT BE BAD
STEP 7) NOW TO REALIGN IT. MAKE SURE THE CD TRAY SLIDE, THE WHITE PIECE, IS ALL THE WAY TO THE LEFT.
STEP 8) WE ARE GOING TO SLIDE THE TRAY ALL THE WAY IN, BUT MAKE SURE ITS DONE IN A 45 DEGREE ANGLE AND THAT THE TRAY IS ONLY CONNECTED TO THE RIGHT. ONCE ITS IN ALL THE WAY LOWER THE TRAY TO THE LEFT SIDE. IF IT HITS THE PIECE IN THE BACK-LEFT PULL IT A BIT FORWARD. IT SHOULD FALL IN EASILY. NOW TURN THE PS2 ON AGAIN AND EJECT THE TRAY, HOPEFULLY IT OPENS ALL THE WAY. IF IT DIDN'T START AT STEP 5 AND START AGAIN. SOMETIMES IT TAKES 2 OR 3 TIMES TO GET IT INTO THE RIGHT PLACE. ANY Q EMAIL FELTON IWHYOU@YYAHOO.COM
Dec 28, 2008 | Sony PlayStation 2 (PS2) Console
Programing
To set to free play you simply move the wire jumpers in the credit unit. (It's the white box on the right hand side below the mechanism).
You move the two left jumpers to go from 0 to F (freeplay!) and the jumper to the right of it from 1 to 7 (maximum credits=49)
Then either switch off/on to reset or press the LT button once.
Remember that if you have programmed it for less than 100 CDs in the carousel that 00 will not work as that is technically CD 100.
Dave.
May 21, 2008 | Wurlitzer Jukebox 1015 One More Time...
Drawer came off track
You need to open it, lift two tabs at the back of the tray on each side to allow you to remove it, then re-insert making sure it's back on the rails.
Mar 10, 2007 | RCA CDRW120 2-Disc CD Recorder
Disk tray stuck.
My CD ROM try needs to be tightened, can you help me?
Jan 10, 2007 | GE 5803P Multi-disc DVD Player
Nu Mark Numark Cdn36 Dual CD Player CD Player Logo
117 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
