Question about Garden
User instructiuons for danfoss tp 5.2 controller
CENTRAL HEATER PROGRAMMER
2 Suggested Answers
  • 173 Answers
SOURCE: setting clock on timer for danfoss tp 5000
http://www.alde.co.uk/downloads/alde_tp5000_user.pdf
click the link and will get the instruction of how to set clock on timer
Posted on Dec 16, 2011
1998 cadilac deville passenger side climate control not working, what should the voltage be?
Turn the ignition switch to the ON position.
Turn the passenger climate control to full hot.
Measure the voltage at terminal D13 of the heater and A/C programmer.
Is the voltage measured equal to the specified value?
12 V
YES - Go to Step 2
NO - Go to Step 8
Turn the passenger temperature control to full cold.
Measure the voltage at terminal D13 of the heater and A/C programmer. Refer to Measuring Voltage in Wiring Systems.
Is the voltage equal to the specified value?
0 V
YES - Go to Step 3
NO - Go to Step 8
Press and hold down the passenger temperature control.
Measure the voltage at terminal C16 of the heater and A/C programmer. Refer to Measuring Voltage in Wiring Systems.
0 V
YES - Go to Step 4
NO - Go to Step 9
Release the passenger temperature control.
12 V
YES - Go to Step 5
NO - Go to Step 9
5
Turn off the passenger temperature control.
Measure the voltage at terminal D10 of the heater and A/C programmer. Refer to Measuring Voltage in Wiring Systems.
12 V
YES - Go to Step 6
NO - Go to Step 10
6
Turn on the passenger temperature control.
Is the voltage measured less to the specified value?
12 V
YES - Go to Step 7
NO - Go to Step 10
7
Inspect the terminal contact at the heater and A/C programmer.
If the contact is OK, replace the heater and A/C programmer. Refer to Programmer Replacement .
Did you complete the repair?
System OK
8
Test CKT 831 (DK BLU/WHT) for an open or a short.
If the circuit is OK, replace the passenger temperature control. Refer to Control Assembly Replacement - Passenger .
System OK
9
Test CKT 1336 (DK BLU) for an open or a short.
System OK
10
Inspect CKT 1370 (PPL) for an open or a short.
May 20, 2017 | Cars & Trucks
How do I set the holiday programme on the Danfoss TP 5000si?
Please go to the Mitsubishi Electric product support site for this question, the owners manual will be there as well I assume.
Jan 23, 2017 | Danfoss Garden
REPLACING ac heater programmer in my 1999 cadillac deville
Why ?
Programmer Description
The heater and A/C programmer is attached to a bracket. The bracket is located next to the right end of the heating, ventilation, and air conditioning (HVAC) module assembly, behind the glove box. The heater and A/C programmer provides the controls for temperature regulation.
The heater and A/C programmer controls an electric actuator. The electric actuator adjusts the air mix valve position in order to blend cold and warm air. Vehicles with dual zone (CJ2) have 2 electric actuators that mix the air independently of each other. The motor is reversible and moves a rotary shaft which drives the air mix valve link. The motor also provides a position sensor signal in order to monitor the actual valve position.
The heater and A/C programmer operates the 4 vacuum solenoids. The solenoids control vacuum to the various vacuum actuators. The vacuum actuators control the following components:
• The air inlet valve
• The A/C DEFROST valve
• The UP/DOWN valve
The heater and A/C programmer also controls the park brake release actuator. The powertrain control module (PCM) sends a Class 2 serial data message to the heater and A/C programmer whenever the transmission is shifted out of PARK or NEUTRAL. The heater and A/C programmer will then supply vacuum to the park brake release solenoid, which releases the park brake.
The heater and A/C programmer sometimes is referred to as the air control module (ACM). This reference is commonly used by a scan tool and by the diagnostic trouble codes (DTCs).
Dec 20, 2016 | 1999 Cadillac DeVille
The hw/ hw+ch rocker switch on my danfoss set 2e heating programmer is not working
Rocker switch stuck on replace programmer or diverter valve stuck in ch postion .
Aug 13, 2012 | Heating & Cooling
Danfoss TP5 programming manual required
This is the full manual:
http://danfoss-randall.co.uk/PCMPDF/6218.pdf
Very well hidden away on the Danfoss website!
Oct 29, 2009 | Honeywell Electronic Programmable...
I've a problem with my central heating, I've changed my central heating programmer to a drayton lp522. My heating is constantly on. The only way that I am able to turn it of is with the thermostat when I...
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Dec 03, 2008 | Water Heaters
Instructions on programming a Randall 102E controler on our central heating system please.
here's some links to some pdf files that can assist you
http://www.bhl.co.uk/uploads/article331/Danfoss_CP715.pdf
http://www.plumbnation.co.uk/site/danfoss-randall-102e5--24-hour-gp-mini-programmer/102E5%20Guide.pdf
Hope to be of assistance to you all,
Sincerly, alexander
Apr 29, 2008 | Heating & Cooling
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
