My sony dvp fx970 wont play some dvd's
Screen says it is loading then it shows some preview screens then screen goes dark. Or no preview screen at all, just says its loading. Disc is still spinning but no sound or video. About half of the dvd's I put in it it says it "cannot read disc". It is a crapshoot if my player will play the dvd's I buy or not.
  • 35 Answers
SOURCE: Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Posted on Mar 02, 2009
supertech6
  • 513 Answers
SOURCE: sony dvp-fx810; install dvd; display says
You can try cleaning the laser lens.
CAUTION!! The lens is delicate! I wipe DVD lenses with ONE drop of glasses cleaner on a Q-tip and, starting in the center, wipe in circles to the outside. Do not press down! Do not force the lens side to side. It will move while cleaning but don't put more pressure than needed to move the lens 3/4 way down!
Its a cheap test to see if there is a fingerprint on the lens. (You won't be able to see it - does not take much)
If this does not help, it means it needs a laser or worse. Probably just replace the player.
Posted on Mar 21, 2010
Testimonial: "thanks again"
SOURCE: Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Posted on Jul 18, 2010
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
welcomejee
  • 10594 Answers
SOURCE: we have a DVP FX
Yes, it is fixable, replace optical laser block of DVP-FX875 to solve its issue.
Let me know if you need part number of optical laser block or contact local tv repair shop for replacement.
Thanks.
Posted on Oct 31, 2010
Connect iPod Classic to Sony DVP-FX970 portable DVD Player
You may refer to this tutorial, it's about how to connect iPod to TV, it should also work for DVD player.
http://www.reviewstown.com/how-to-connect-ipod-iphone-ipad-to-tv.html
Hope
it helps. Contact me if you have any other question.
Jun 03, 2013 | Televison & Video
Can I connect my to iPod Classic to watch video on Sony DVP-FX970 Portable DVD player? If so, what connection do I need?
The DVP-FX970 uses a composite (3xRCA) to mini-AV (2x mini-plugs) reducing cable. This is Sony part 9-885-103-56 and was included with the DVD player in the original packaging. See https://sony.encompass.com/item/7054170/Sony/9-885-103-56/Av_Cable_(010-0001-206) . Other vendors may also have the cable. You will also need an RCA (3xF) coupler, see http://www.cablestogo.com/product/40647/composite-video-stereo-audio-f-f-coupler-taa-compliant for one option. Connect the composite end of the above cable to one side of the coupler and the other side to the DVD player. Next connect the appropriate iPod Classic video dock, https://www.apple.com/shop/product/MC748AM/A/apple-composite-av-cable , to the other side of the coupler and the iPod Classic. Now, turn on everything and press the Input Select button for the DVD player multiple times until the current input is 'Line In'.
I hope this helps.
Jun 24, 2017 | Televison & Video
Dvp-fx970
here is an answer anyway--if will not play a disc "cannot play disc etc" usually it is either a dirty or bad optical pickup in the unit.
May 20, 2012 | Sony DVP-FX730 Portable DVD Player
Sony portable DVD player dvp-fx970 won't play dvd
Use lens cleaner TDK or wash dvd disks with hot tap water then block off the water drops.
Feb 08, 2012 | Sony Televison & Video
Unlock code needed for Sony DVP FX-970
May I ask what code you are looking for. If it is a code to unlock the region to make it region free there is no code out yet. Also it is almost imposable to unlock portable DVD players.
May 19, 2011 | Sony DVP-FX820 DVD Player
Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Jun 19, 2010 | Sony DVP-FX730 Portable DVD Player
Sony DVD player DVP-NS700H unable to play DVDs.
the dvd player lens damaged. -please change it with good technician
Sep 21, 2009 | Sony DVP-NS700H DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
