Question about Audiovox FPE1078 7.8 in. TV/DVD Combo
Receiving tv programs
I can only get channels 2 - 13 on the tv, even though I have cable tv. I've gone through the steps of being in the tv mode and pressing AUTO to search the channels automatically. Still, it will only go to channel 13. I've tried the up and down arrows and inputing a channel number, but nothing seems to be working. There is nothing else in the manual that addresses this problem. What do I need to do to remedy this?
I had the same problem, and finally pressed the TV/CATV button on my remote, and everything was back to normal.
Posted on Jul 24, 2009
    President:
  • 3,130 Answers
In the menu theres a channel set up mode. You want to switch from antenna to cable mode, then do an auto search. Then all your cable channels will come in. Your going to need the original remote to go into the correct menu. good Luck
Posted on Aug 25, 2006
Sanyo tv ds25030 how to program chanals 48-96
Your TV must be set in cable mode for channels higher than 69, and your cable provider must allow those channels to be received without a cable box. Menu, Channels, switch air to cable, run auto scan. If it receiving those channels unencrypted, it will find those channels.
Mar 10, 2015 | Sanyo Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Channel scan only finds 1 channel with basic cable setup on LG 42LD520
if you have a cable box just plug the cable box into a scart socket on the tv, switch the tv to the scart input and use the cable remote to change channel?Scanning for channels wont find anything because you are receiving the channels on a cable box. If you are refering to standard or digital tv signals and your not receiving any channels then either you are only scanning analogue tv and therefore wont pick up any digital tv channels, or your ariel is inadequate to receive an acceptable digital reception and will need to be upgraded. please state country you are in and what you are expecting to receive
Apr 13, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
No Picture and No Sound on all Analog Channels
Ur tv shouldn't set in cable mode, if u don't have pay cable,or satalite,extra..Should set in air channels.Buy a digital antena or out side roof antena u get all the channels airs.
Aug 19, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
!995 GE TV Model # 27GT615
I don't recall the exact incantation, but one of the menus will allow you to change the TV from Air channels to cable. You are currently in the antenna mode. Only channels up to 12 will be even close to the cable ones. On a set of that vintage, there may even be a slide switch on the front of the set.
Dan
Aug 20, 2008 | GE Televison & Video
I cant get the tv to go to higher channels
Most tv's have an Antenna mode and a cable mode. If you have cable tv service, the cable mode must be selected in order to receive channels higher than 23. Then you must auto program the channels thru the menu screen on the tv to receive the channels above 23. If you have a house antenna or rabbit ears, its hit or miss on receiving all VHF and UHV channels.
Jan 12, 2008 | RCA 20V500T 20" TV
Toshibe 36AFX61 36" TV
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
Sep 18, 2007 | Toshiba 36AFX61 36" TV
Audiovox FPE1078 7.8 in. TV/DVD Combo Logo
299 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
