Question about Royal Sc120 Shredder
My shredder squeaks when in use, does it need regular lubrication? If so, what do I use?
My shredder squeaks when in use, does it need regular lubricating? If so, what type of lubricant is required?
  • 488 Answers
Visit the link below for various types of shredder oils.
http://www.factory-express.com/Shredder_Oil__Bags-2025.htm
Regular use of paper shredders creates paper dust that can dry out components, dull the blades, clog the machine and burn out the motor. However, with proper oiling and maintenance, a paper shredder can last for years.
Oiling a shredder can be accomplished using one of two quick methods. The paper method limits excess oil to the paper, reducing the chance of it splattering when you turn the machine back on. This method is more common than the second and can be used with all kinds of shredders. The paperless method may be less common, but it is just as effective at removing dust buildup from the blades of the shredder.
The Paper Method:1. Place a sheet of paper on or above a surface that will not be marred or damaged should you spill oil on it.2. Apply the oil to one side of the paper in a wide zigzag pattern across the whole face of the page to ensure sufficient coverage. Do not saturate the paper with oil.
3. Turn the shredder on and run the oiled piece of paper through the shredder. As the paper shreds, the oil that has been absorbed by the paper will lubricate the blades. The motion of the blades will distribute oil so the shredder continues to operate smoothly.
3. Feed a few more papers into the shredder to absorb residual oil from the cutting assembly. The Paperless Method:1. Set the shredder to manual mode so you can control the direction of the blades and the amount of time the blades are in motion.2. With the paper shredder turned off, squirt a solid line of oil into the paper entry lengthwise across the paper-shredder blades.
3. Start
the paper shredder in reverse, allowing it to run for 10 to 20 seconds before stopping the blades. This will evenly distribute the oil to all parts of the cutting assembly.
4. Return
the shredder to automatic mode. Then feed two or three sheets of paper into it to absorb the excess oil from the machine. Tip:
How often you should oil your paper shredder depends mostly on how much you use it. Office shredders that see heavy use every day will need to be oiled several times a week, while home machines used occasionally need be oiled only a few times a year. Cross-cut shredders will require more frequent oiling than other paper shredder varieties because they have more blades and create much more paper dust.
You can purchase a shredder lubricating oil from any major electronic or office supplies store or you can contact Royal customer service at 908-429-4357.
Posted on Feb 21, 2012
Testimonial: "Oiled the shredder, and it works like a champ now. Thanks!!!"
4 Suggested Answers
SOURCE:
  • 1218 Answers
SOURCE: My previous shredder was supposed to be oiled
If it is a x-cut shredder then it will not hurt( infact it is advisable) to occassionaly shred a sheet of paper with some shredder oil on it.
How frequently....the more you shred the more you should oil it.
Posted on Aug 29, 2010
  • 1218 Answers
SOURCE: My shredder quit working.
First thing you have to do is clear all jammed paper. Second..try running machine; if the motor runs and the blades turn put some shredder oil into the cutting blades as lubricant. If the motor wont run you have probably blown the pcb because of too much paper... to get replacement part call Royal at 1-800-524-0799.
Posted on Sep 05, 2010
  • 1218 Answers
SOURCE: How do open the machine
Best way to lubricate is just to put the oil in an "S" pattern on a sheet of paper and shred just that one sheet. My have to do that a few times if its never been lubricated.
Posted on Jul 20, 2011
What can be the reason that in back of my 2012 dodge journey as I hear there is an army of mice, squeak ?
Suspension bushings need lubrication? These are rubber, and don't take regular grease, but do require lubricant.
May 22, 2015 | Dodge 2012 Journey
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
Needs lubricating
So try lubricating the unit check out this link...
http://www.fixya.com/support/t2659854-shredder_lubricant_sheets
Should cost less that $12 for a package of sheets. Try one and see if the screeching stops.
Good luck..
Jun 27, 2014 | Fellowes Powershred 380 Shredder
Shredder is squeaking
You would need to lubricate the unit by running through oiled paper or by spraying oil directly into the feed opening and then running unit in reverse for at least 2 minutes Good luck
Aug 23, 2013 | Quartet gbc Office Equipment & Supplies
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
How frequently should shredder be lubricated, and where should lubrication be applied?
The lubrication is applied directly to the cutting blades in a back & forth motion right to left. Oil it, then turn it on to work in the lubrication & repeat to make sure everything is covered.
How often you lubricate depends on how often you use the shredder & the type of items you put into it. I would suggest lubricating bi-weekly for moderate use with regular paper. Increase if you are using card stock, plastic cards or large quantities in a single session.
Sep 21, 2011 | Techko SH1524CP Shredder
Shredder shreds much slower plus the machine is making a loudnoise
Have you ever "oiled" the machine.??? Put some shredder oil onto the cutting shafts to give some lubrication,...all x-cut shredders need regular oiling.
Jan 16, 2011 | Dynex DXOP7CC (CrossCut) Shredder
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
What type oil do you need for an electric chainsaw?
you need to buy chainsaw lube oil, its red and lubricates the chain.chainsaw chain lubricant. plz rate-bozcro
Sep 10, 2009 | Heavy Machinery
Royal Sc120 Shredder Logo
5,914 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
