Question about Toys
1994 jcb 214 backhoe transmission problems
Works fine for a bit then seems to lose all power in drive,reverse is fine
2 Suggested Answers
udesh99
  • 97 Answers
SOURCE: Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
Posted on Sep 23, 2009
I have a 1994 jcb 214 sitemaster backhoe steering is stuck in crab mode and will only move second gear but if I step on the brake it work in all gears
Sounds like you have a sensor wire crossed or out of connection. Touching the brake makes the brake light come on and is doing a re-connect. Check that out, it's gotta be in the electrical system as you can now understand. Something is crossfeeding and/or backfeeding power to where it shouldn't.
Aug 17, 2017 | Cars & Trucks
I have a JCB 214 series 3 1995 it will not move it was working fine going forward and reverse then it just stopped and it was always kind of hard to switch into different gears but now it just slips very...
Needs a clutch. Not cheap your gonna have to pull the transmission the clutch pack is reasonable 150.00 to 225.00 its the labor that is expensive. Don't recommend doing it yourself unless you are up to the task and have the ability and the tools,some special alignment clutch tools. ASE master certified mechanic.
Jan 05, 2015 | Cars & Trucks
Diesel engine knock
could be a bad knock sensor
Jul 17, 2014 | Jcb Bruder JCB Loader Backhoe
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Where i can order jcb 3cx part?
try paul martin servicess @ aberdare s/wales
Nov 29, 2010 | Jcb Bruder JCB Loader Backhoe
Jun 14, 2009 | Bruder Jcb 4CX Loader
Open Questions:
Toys Logo
153 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
