Question about TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP PRINT AND STORAGE SERVER RTL - TL-PS310U T... (6935364031060) Print Server
TL-PS310U custom firmware
Need found a custom firmware to TL-PS310U that makes it works with samba.
I have a tl-wr 740N and my mac connects fine to the wireless but the two mobile phones that we want to connect sometime work and sometimes don't. It seems like only one phone will ever be able to be c
My first take would be to make sure that the firmware is up to date. Often enough connectivity issues can be resolved this way.
Take a look at TP's support page here:
150Mbps Wireless Router TL WR740N
(Make sure you find the correct version of your router. I am also assuming you did not install any other firmware)
If this does not work, I would turn off any wireless security off to see if the phones connect. They definitely should both be able to connect at the same time.
Last resort would be to reset the router to factory default (make sure to have username and password from your ISP in case you need it.)
Let me know if one of these tips helped.
PS: What type of phones are you using? Android or iPhone?
Jan 16, 2015 | TP-LINK TL-WR740N Router
I have a tplink PS310U MFC print server. I have managed to connect using a PC but there is no software for the Mac OS X. I am running Yosemite and can connect to the server for printing. However I can
Hi
If you can't scan then it sounds as if your computer doesn't have the appropriate driver installed for scanning. There are a lot of drivers and other downloads here:
Printers
including a scanner driver for MAC OS 10.3 to 10.7. Since Yosemite is 10.10, I don't know if this would work for you, but I think it your most promising solution.
It may be worth disconnecting the printer and connecting it directly to the computer. If it scans and prints when directly connected then it is likely that the print server is causing the problem and if as you say there is no Mac software for it you may be in a no-win situation. The fact that you can print through it however does mean there is hope, because I have found this page which is described as manual installation of the server on Mac OS here
FAQ ID 347 How to install Print Server manually on MAC OS
but the OS is 10.6.4 so, I'm not sure.
Not as helpful as I had hoped but perhaps you can get something from this screed
Dec 17, 2014 | TP-LINK ACCESSORY TL-PS310U SINGLE...
TP-LINK TL-WA730RE is not allowing internet access due to DNS not be broadcast correctly. Skype and outlook (no DNS needed) are working fine.
yeah same here. You have to find a way to give the DNS settings to WA730RE.
2 Options or use the Dynamic mode of getting the ip in the WA730RE or use a custom firmware where u can configure this setting.
Jun 22, 2011 | TP-LINK TPLink (TLWA730RE) Wireless Router
Singer Samba 6 sewing machine
It would be wise to have the machine cleaned & serviced. Do you have a manual for it? Did it come with oil at one time? I found a free manual at
http://homeappliance.manualsonline.com/manuals/mfg/singer/7442.html
You have to register (free)...choose to skip the popups (2)...and you can save the manual to your hard drive.
I checked the manual...you don't need to oil the machine...but page 61-63 shows cleaning...and it's basic. You take the two screws from the throat plate, remove the bobbin case & brush the inside of the machine bed out...I use a small artists plastic bristle brush, or a small childs tooth brush.
Hope this helps.
May 14, 2010 | Singer 7442 Mechanical Sewing Machine
I need the drivers for the samba 845gv
Go to manufacturers web site
There you can find all the drivers you may need
Nov 17, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
My psp don't have Iso folder
After you install custom firmware you need to format the memory stick from the psp that will solve your problem. Remember if you format it all the data will be deleted so make sure to back up.
Jan 16, 2009 | Sony PlayStation Portable (PSP) Slim...
Upgrade CPU In my SAMBA SM-1845
Hi, as long as both chips are slot 478 it should work fine, you wont need to change any bios or jumpers, just open up the computer, remove the heatsink, lift the lever and remove the CPU.
Insert new processor.
you will need thermal grease at this point, you need to apply a little amount onto the cpu, and make sure the old thermal paste is removed from the heatsink and then refit the heatsink & fan.
other option is fit the new cpu and purchase a new heatsink & fan, they usually come with the thermal grease, a new heatsink will cost about £10 or themal grease by itself will cost about 2-3 pounds.
just make sure you have new thermal paste before you remove the heatsink as the processor will get damaged otherwise..
Hope this helps
John
Jul 31, 2008 | FIC Samba SM-1845 (SM1845GV) Barebone
Scan-to-smb fails on SAMBA share
Hello, I have the same problem wih a Bizhub 500 and samba on SLES 9
Jul 22, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
How to configure samba server
Hi satveergaur
Follow these instruction to configure samba server
To configure Samba using a graphical interface, use the Samba Server Configuration Tool.
The Samba Server Configuration Tool is a graphical interface for managing Samba shares, users, and basic server settings. It modifies the configuration files in the /etc/samba/ directory. Any changes to these files not made using the application are preserved.
To use this application, you must be running the X Window System, have root privileges, and have the redhat-config-samba RPM package installed. To start the Samba Server Configuration Tool from the desktop, go to the Main Menu Button (on the Panel) => System Settings => Server Settings => Samba or type the command redhat-config-samba at a shell prompt (for example, in an XTerm or a GNOME terminal).
Note
The Samba Server Configuration Tool does not display shared printers or the default stanza that allows users to view their own home directories on the Samba server.
 Configuring Server Settings
The first step in configuring a Samba server is to configure the basic settings for the server and a few security options. After starting the application, select Preferences => Server Settings from the pulldown menu. The Basic tab is displayed as shown in Figure 24-2.
 Configuring Basic Server Settings
On the Basic tab, specify which workgroup the computer should be in as well as a brief description of the computer. They correspond to the workgroup and server string options in smb.conf.
 Configuring Security Server Settings
The Security tab contains the following options:
Authentication Mode — This corresponds to the security option. Select one of the following types of authentication.
ADS — The Samba server acts as a domain member in an Active Directory Domain (ADS) realm. For this option, Kerberos must be installed and configured on the server, and Samba must become a member of the ADS realm using the net utility, which is part of the samba-client package. Refer to the net man page for details. This option does not configure Samba to be an ADS Controller.
Domain — The Samba server relies on a Windows NT Primary or Backup Domain Controller to verify the user. The server passes the username and password to the Controller and waits for it to return. Specify the NetBIOS name of the Primary or Backup Domain Controller in the Authentication Server field.
The Encrypted Passwords option must be set to Yes if this is selected.
Server — The Samba server tries to verify the username and password combination by passing them to another Samba server. If it can not, the server tries to verify using the user authentication mode. Specify the NetBIOS name of the other Samba server in the Authentication Server field.
Share — Samba users do not have to enter a username and password combination on a per Samba server basis. They are not prompted for a username and password until they try to connect to a specific shared directory from a Samba server.
User — (Default) Samba users must provide a valid username and password on a per Samba server basis. Select this option if you want the Windows Username option to work. Refer to Section 24.2.1.2 Managing Samba Users for details.
Encrypt Passwords — This option must be enabled if the clients are connecting from a Windows 98, Windows NT 4.0 with Service Pack 3, or other more recent versions of Microsoft Windows. The passwords are transfered between the server and the client in an encrypted format instead of in as a plain-text word that can be intercepted. This corresponds to the encrypted passwords option. Refer to Section 24.2.3 Encrypted Passwords for more information about encrypted Samba passwords.
Guest Account — When users or guest users log into a Samba server, they must be mapped to a valid user on the server. Select one of the existing usernames on the system to be the guest Samba account. When guests logs in to the Samba server, they have the same privileges as this user. This corresponds to the guest account option.
After clicking OK, the changes are written to the configuration file and the daemon is restart; thus, the changes take effect immediately.
The Samba Server Configuration Tool requires that an existing user account be active on the system acting as the Samba server before a Samba user can be added. The Samba user is associated with the existing user account.
To add a Samba user, select Preferences => Samba Users from the pulldown menu, and click the Add User button. On the Create New Samba User window select a Unix Username from the list of existing users on the local system.
If the user has a different username on a Windows machine and will be logging into the Samba server from the Windows machine, specify that Windows username in the Windows Username field. The Authentication Mode on the Security tab of the Server Settings preferences must be set to User for this option to work.
Also configure a Samba Password for the Samba User and confirm the Samba Password by typing it again. Even if you select to use encrypted passwords for Samba, it is recommended that the Samba passwords for all users are different from their system passwords.
To edit an existing user, select the user from the list, and click Edit User. To delete an existing Samba user, select the user, and click the Delete User button. Deleting a Samba user does not delete the associated system user account.
The users are modified immediately after clicking the OK button.
Starting and Stopping the Server
On the server that is sharing directories via Samba, the smb service must be running.
View the status of the Samba daemon with the following command: /sbin/service smb status
Start the daemon with the following command: /sbin/service smb start
Stop the daemon with the following command: /sbin/service smb stop
To start the smb service at boot time, use the command: /sbin/chkconfig --level 345 smb on
Regards,
TheAssembler
Jun 06, 2008 | Computers & Internet
Open Questions:
See all TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP Questions
TP-LINK ACCESSORY TL-PS310U SINGLE USB2.0PORT MFP PRINT AND STORAGE SERVER RTL - TL-PS310U T... (6935364031060) Print Server Logo
531 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
