Question about HP PSC 2210 All-In-One InkJet Printer
Language 5400 how do i change it can't find the tools
  • 4 more comments
  • laurievilnef Oct 27, 2008
    there is no setup on a 5470 and no tools under the menu
    there is no setup button
    lexmark 5470 don't know the model number there is no setup button and no tools no matter how many times i push menu
    i troed that several times no tools menu exactly how many times and its in some other language
    serial number s02320061855 how do i find the make and model nope
    nope didn't work either theres no select button
    President:
  • 1,901 Answers
Setting the front panel language on the HP PSC 2200 series To set the language and region, follow the steps below:
  1. On the all-in-one front panel, press the Setup button five times, and then press Enter to access the Maintenance settings.
  2. Press the number 5 on the front panel numeric keypad, and then press Enter to access the Language and Region settings.
  3. The available languages will appear in the display. Press the Right Arrow (>) button to scroll through the available languages. Enter the two-digit code for the desired language based on what is listed in the display (example - 11 for English, 12 for Spanish, and etc.).
  4. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the language and try again.
  5. The available regions will appear in the display. Press the Right Arrow (>) button to scroll through the available regions. Enter the two-digit code for the desired region based on what is listed in the display.
  6. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the region and try again.
Posted on Oct 27, 2008
  • 4 more comments
  • Wayne Mineard
    Wayne Mineard Oct 27, 2008
    Sorry, you have this listed under PSC 2210 All In One Inkjet.
  • Wayne Mineard
    Need to know exactly what product you are trying to correct. You have 5400, 5470, and listed under PSC 2210. Please post the exact make, model, and operating system you are using. Thanks.
  • Wayne Mineard
    OK, here it is:
    On the control panel press COPY MODE.
    Press
    Press < or > until TOOLS appears. Then press
    Press < or > until DEVICE SETUP appears. Then press
    Press < or > until LANGUAGE appears. Then press
    Press < or > until you get the language you want.
    Press to save your settings.
  • Wayne Mineard
    Any idea what language?
  • Wayne Mineard
    OK, try this:
    If you have accidentally selected another language and now want to reset the printer to English, do the following:
    1. Disconnect and reconnect the power cable.
    2. On the printer panel, press the left arrow once and then the Select button twice to reach the Language menu.
    3. Then keep pressing the right arrow until English appears. Press Select.
    4. If the menus are different from this, you can also try right arrow x 6, Select x 2, right arrow x 1, Select x 1, but the first method is probably more accurate and is certainly easier.
      Important: Be sure to reset the power first so that you know where you are starting from. If you have accidentally wandered into the Frames menu or any other menu, the above code will not work.
  • Wayne Mineard
    I believe the "Select" button is the check mark.
How to reset mac book key board
Did you do this? Under SYSTEM PREFERENCES click on LANGUAGE & TEXT, then INPUT SOURCES and uncheck the boxes for all but the language you want. (You can pick more than one). Then before you leave, click on the bottom where it says "Show Input Menu in Menu Bar." The Menu Bar will show you the flag from the country whose language you have selected. If you click on that, you will see the other languages you've checked and can change them. Hope this helps.
Oct 19, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I can not set English on my 5400 it is stuck on German. How can I change the language to English?
Changing the Display Language
To change the display language, please execute the following steps:
Step Action 1 From the control panel, press Copy Mode. 2 Press pattlnk_10122006_1256-menu.jpg. 3 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until Tools appears. Then press the pattlnk_10122006_148-okay2.jpg button.
4 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until Device Setup appears. Then press pattlnk_10122006_148-okay2.jpg. 5 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until Language appears. Then press the pattlnk_10122006_148-okay2.jpg button. 6 Press pattlnk_10122006_148-arrow_left.jpg or pattlnk_10122006_148-arrow_right.jpg repeatedly until the language required appears on the display. 7 Press pattlnk_10122006_148-okay2.jpg to save the change.
Jun 07, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have just bought a garmin nuvi 1300 and when turned it on the language is german or dutch. We need english but cannot figure out how to change to that seleciton. Help??
can u look for this words here i think it may help you.
Werkzeuge---Tools
sprache---language this is for german language
taal---language
tools--tools this is the same this is dutch language i think it might help
Mar 04, 2011 | Garmin nuvi 1300 Car GPS Receiver
I bought a Garmin Nuvi 1350 GPS. How do I change the language into English?
. Setting the Languages Voice Language--change the language for voice prompts. Touch tools > Settings > Language.
text Language--change all onscreen text to the selected language. Changing the text language does not change the language of user-entered data or map data, such as street names. Keyboard--select the keyboard for your language.
Touch Mode on any keyboard to change the keyboard language.
Sep 02, 2010 | Garmin GPS
Need to change language on Garmin 1350
Touch 'Tools' icon (bottom right corner in Main Menu). Then touch 'Settings', then 'Language'. You can change voice and text language there. Changing the text language does not change the language of user-entered
data or map data (street names, etc).
Jun 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
How do i change the language on an 885t garmin. I
Here are the directions to resetting the Garmin Nuvi 885T language settings.
To change the language settings of your Garmin Nuvi 885T touch the following icons:
  1. Tools
  2. Setting
  3. Language
Then select your preferred language from the list.
'Tools' is the wrench in the bottom right corner, labeled '9'.
'Settings' is the wrench in the top left corner.
'Language' is the mouth in the bottom right corner.
I hope that helps.
For more Garmin Nuvi 885T help, see my other Nuvi 885T Tips: Hard Reset and Unfreeze.
Jan 22, 2010 | Garmin nuvi 885T GPS Receiver
Garmin 265 W won't speak street names
Below is the procedures for setting the languages...
Touch tools > settings > language > voice.
Voice- changes the language for voice promts.
Languages noted with a persons name are (tts)
text to speak voices.
which have an extensive vocabulary and pronounce
the street names as you approach turns.
The pre-recoreded voices (those without a persons name)
have a limited vocabulary and (do not speak names of locations or streets)
Text language- change all on-screen text to the selected language,
changing the text language does not change the language of user entered data
Keyboard- select the keyboard for your language,
you can also change the keyboard language mode from any keyboard
by touching the mode button
Adjusting the volume levels
From the "menu" page touch "volume"
to adjust the volume.
To adjust the volume levels for the media player
and the navigation prompts,
please click.
Tools > settings > Volume > Restore
Restore will, restore to origional volume levels.
Regards
Richard
Apr 26, 2009 | Garmin nuvi 205W GPS Receiver
Was stuck on chineese, must,change language on lm 4800
You'll need to reset the factory defaults.
Download the User Guide (PDF) from here:
http://www.lexmark.com/publications/pdfs/2007/4800/en.html
(I'm assuming you have the something in the 4800 series of printers, though you posted your question in the 5400 series section)
Go to page 56&57 and follow the directions there.
If you have the 5400 series, the link is here:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
See page 123.
Apr 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Garmin 780
please click.
You should be good now
Regards
Richard.
Jan 23, 2009 | Garmin nuvi 780 GPS
HP PSC 2210 All-In-One InkJet Printer Logo
70 people viewed this question
Ben Johnson
