Question about Admiral AW22 Top Load Washer
Water comes up into our tub when washer drains
Seems whenever we do a load of laundry our tub fills up and see lint in the water , we are renting this house and getting tired of haivng to manually drain the tub to shower/bathe , helllp!! lol thanks
    Scholar:
  • 116 Answers
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Posted on Nov 09, 2008
Lint all over Clothing after rinse.
My washer accumulates lint between the wash tub and the outer chamber. Whenever you wash a load, all the past dried up lint gets reactivated into the new wash water.
If you get a refrigerator or dryer lint brush, you can reach this area and brush out the accumulation. Also the area above the wash tub can get clogged with lint. If you look under the lip between the tub, you can see the fabric softener/bleach channel dispenser, a lot of lint can accumulate there as well.
Clean both areas after a recent wash load when the lint has softened and is easy to scrub off. For safety's sake, unplug the washer. Be ready to be grossed out! I clean my washer every now and then to keep the lint down.
The washer will smell nice and clean after getting this lint/dirtball out. To maintain this lint free environment, see below.
If this fails and is not the problem, go to a thrift store and purchase the cheapest 100% pure wool clothing, some dark colors, and some white. The wool acts like a magnet for lint and will attach itself to the wool before it attaches to your clothes. It can be used over and over if you hang it out to dry. It will get felted and covered with lint.
Mar 15, 2014 | Roper Washing Machines
Magkakatuluyan ba kami ni shelumiel
Instructions
things you'll need:
* Laundry detergent
* Clean cloths
* Measuring tape
* Plywood (if necessary)
* Wrench (if necessary)
1.Verify that the Kenmore top-loading washing machine is completely plugged into a grounded, three-prong power outlet. Reset the fuse or circuit breaker, if necessary; do not plug the washing machine into an extension cord.
2.Make adjustments to the feet on the washing machine if it is shaking or vibrating. The front and rear feet must all be touching the floor evenly. If the floor under the machine is flimsy and cannot adequately support the washer, set a 3/4-inch piece of plywood under the machine for better stability. Load the tub evenly when placing items inside the washing machine and do not overload the tub.
3.Examine the washing machine drum, including between the inner and outer basket, if the machine is clicking or rattling during use. Remove loose objects from inside the drum. If objects are caught between the drums, unplug the washing machine and pull the items out with a pair of pliers, if possible.]
4.the fill hoses behind the washing machine if there are water leaks and ensure the drain hose is connected to a laundry tub or drainpipe. Look at the plumbing throughout the home for drainage problems and correct as necessary.
5.Turn on the water valves behind the washing machine and clean the water inlet hose screens if the water is not running or filling. Do not overload the tub, and use only high-efficiency (marked HE) laundry detergent in high-efficiency Kenmore washers. Note that energy-efficient washing machines often use less water than other machines; this is normal.
6.Choose a wash cycle with a higher spin speed if the water is not draining as expected or items are extremely wet when washing is complete. Reduce overall load size and select a new drain/spin cycle to remove the extra water from the washer. Ensure the drain hose is properly installed on a drainpipe or tub and is not set more than 96 inches above the floor.
7.Reduce the number or volume of items inside the washer tub if the clothes are not rinsed when the cycle is complete. Verify that the water valves are turned on and the correct type and amount of laundry detergent is used.
Mar 12, 2011 | Kenmore 22422 Top Load Washer
My washing machine drain line seems to be clogged. Washer seems fine so I have deduced that the drain line is either clogged or isn't ventilated properly on my roof. Is there a way to determine which...
First off if you don't have plastic pipe chemicals will eat up,most laundry's have a floor drain if thats backing up then your drain is plugged.A lot of laundry set-ups are on the same drain as kitchen and the two together are a problum sometimes.Drain-o is not the way to go,I would rent a small drill auger or get your neighborhood drain guy to unplug,some laundry lins have a 25-30 ft run under the concrete and can be a task for homeowner,ps if your draining into laundry tub check strainer for lint
Jan 28, 2011 | Plumbing
Fills with water and does not drain
It won't drain If your washer won't drain, check these: It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.. It doesn't spin or pumpIf your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.It pumps, but the water returnsIf the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
Jan 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
My washer has water in the bottom of it. I pressed drain and spin it did then it filled back up with water.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 01, 2010 | Kenmore Washing Machines
Washer is partially refilling after spin cycle.
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Asker's Testimonial " Thank you, I was also told that it may be the fill valve?? " - dsmith1695
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Dwd-wd32ws will not drain
Some of the washing machine models have a small pump in the bottom that clogs with lint and stuff. When you disconnect the hose from the pump get ready for alot of water to come out. prevent this by kinking the hose somehow. This was a similar problem GE had with the washer we used to have in apartments. Good Luck. When you find out how to acess the pump the rest should be easy.
Feb 09, 2009 | Daewoo DW500M Top Load Washer
When filling up my washing machine is leaking bad.I cant tell exactly where the water is coming from.I tilted the washer up so I could look underneath and couldn't tell anything was wet,so i turned it on...
Dear Customer,
i'll provide you with some checks,which when performed would stop the leakage from your Washing Machine..
Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
mam i hope this would work out.i request you to please rate this solution if it meets your needs.Thank You
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Washer Tub Fills With Water When Washer is Not On
dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Jan 20, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Admiral AW22 Top Load Washer Logo
156 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
