Question about Mitsubishi VS-60607 TV
My VS-60607 won't turn on
Hit the power button and it clicks for one second and turn off.
  • 1 more comment
  • chrisccraig Nov 23, 2008
    Hit the power button and it clicks for one second and turns off. is this the power supply and if so how much is a powersupply ?
  • Dartagnnon Dec 03, 2008
    My VS-60607 just started doing the same thing yesterday. I carefully cleaned the dust from the circut boards and checked each connection one at a time and tried to turn the TV on after each test. I found that in the front, one of the connections made a difference in the TV staying turned on after I unplugged it and reconnected it. It worked all yesterday evening after that but I am again having the same problem and the same solution isn't making it any better this time. The plug I'm refering to is the six pin plug on the left light tube near the top of the fixture. Any help would be great!
    Thanks in advance.
  • Anonymous Jan 19, 2009
    When i press the on/off button, it click and turn on, but one second later it click again and turn off.
Unit will power on for a second then shut off. power supply ?
Posted on Nov 23, 2008
2 Suggested Answers
  • 7 Answers
SOURCE: My VS-60607 won't turn on
there is a fuse blown in the television keeping it from staying on. after the shutdown press and hold the menu and device/input button for about 5 seconds and the led will blink a 2 digit code with a pause in between. the code will repeat itself. 2.2 is the most common and points to the convergence ics and 1 or 2 5a pico fuses. 2.3 is the next most common and points to a fault on the power supply. goodluck.
Posted on Feb 05, 2009
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
60607 push button to come on and the code came up 2.2 could u please tell me the problem
This is an error for a short in the power supply/mother board. the fault can be traced by isolation of the circuit after checking the power supply - LT side - and proceeding to isolate the drivers which can be suspect.
Oct 02, 2011 | Mitsubishi VS-60607 TV
Mitisubishi 60607 will come on the go right back off
you have a component failure. begin checking the on-board fuses. that should lead you to the circuit that failed. most often it is the convergence circuit. 2nd most is a loss of vertical deflection. this is a tube protection circuit that shuts the set off before it destroys the crt's.
Jan 06, 2010 | Mitsubishi VS-60607 TV
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Skyassoc
Jul 04, 2009 | Mitsubishi VS-60607 TV
Feb 05, 2009 | Mitsubishi VS-60607 TV
Mitsubishi vs 60607 circuit board
this isn't a notorious problem. many problems can cause this. the instant on/off behavior just says there is one of many fuses blown in the television. you can't just replace the fuse, when it fails get a failure code find out what it means and repair the problem. I would recommend paying someone to do it if you don't want to trash your mits set.
to get the code you hold down the menu and input button for 5 seconds after the on/off sequence. it is a 2 digit code with a pause inbetween, example 2 pause 2 pause 2 pause etc. is a 2.2 code
Jan 23, 2009 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Won't turn on right
check your smps in your tv or Ic is collapsed
Feb 17, 2008 | Mitsubishi VS-60607 TV
Tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Oct 07, 2007 | Mitsubishi VS-60607 TV
Need help
If you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors in the power supply or the sweep power supply. Good Luck
Sep 30, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
