Question about Primo 900172 1.0 Gallon Industrial Water Dispenser
Primo hot water not working
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Tip
Wow this is awesome. I was getting so frustrated, but this completely fixed it....
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Apr 25, 2017 | Primo Grills And Smokers Primo Bottom Load...
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
I have a Primo water dispenser, model 900118, top loading. Unit cooled water for a short time but now will not cool or heat water. I can't locate thermostat.adjustment.
If it will neither heat NOR cool (two different units) then I would be tempted to check power is getting to the unit.
If the compressor is silent (not running) AND the hot water element is not working, then I would guess fuse in plug, wire fallen out of back (if a "kettle type" connector), switched off at wall by someone else,. fuse on back of unit possibly?
Aug 07, 2015 | Wine & Spirits
Primo 900133 hot
throw it away and buy a good BUNN
May 26, 2015 | Primo Baby Gear
Primo water cooler 601087
probably needs a thermostat or a element is out
Jul 13, 2014 | Office Equipment & Supplies
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Where is the reset switch on a Primo water cooler model YL1136S
My Primo Model:YL1136S Hot Water Quit Working How Do I Repair It
Aug 24, 2012 | Baby Gear
Primo water cooler
I JUST BOUGHT A PRIMO BOTTOMLOADING WATER DISPENSER AND ITS BEEN ON ALL NIGHT AND THE WATER IS WARM. I LOOKED ON THE BACK TO SEE IF THERE WAS A WAY TO TURN IT UP BUT FOUND NOTHING. PLEASE TELL ME WHAT TO DO. RNMALIN@ COMCAST.NET
Jan 06, 2012 | Primo 900172 1.0 Gallon Industrial Water...
Primo 900172 1.0 Gallon Industrial Water Dispenser Logo
41 people viewed this question
Top Primo Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Primo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
