Question about Acer Computers & Internet
Acer 3660 try to upgrade from 512 to 2gb,,does not run with 2 x 1gb
Only runs with 1 sodimm ram other port not working
  • joecoolvette
    joecoolvette Feb 21, 2012
    You have to use DDR2 at 533MegaHertz, or 667MHz. That is PC2-4200 and PC2-5300, respectively. (SO-DIMM for laptops, and PC2-4200 is also known as PC2-4300 ) Ram memory Always has to be in Slot 1. (DIMM 1)The Processor reads Slot 1, First. What is the manufacturer name, and manufacturer code on the ram? You may have High-density ECC ram, which you cannot use. (Is it from Ebay?) It may be high performance ram memory, that uses above the factory default voltages for the laptop. It may have the wrong ram timings.  Post back in a Comment.
  • angusclayton
    angusclayton Feb 22, 2012
    thankyou joe,,it is my childs acer 3660,,it does say and recommend 2 x 1gb ram but only the bottom port works with 1gb when i put other ram in it wont even power up,,,i have the correct kingston ram,
  • 807 Answers
Probably a faulty ram socket. I have seen a few acer's with the same problem. There is a sort of fix but it's not normal. It was to insert something between the top ram board and the plastic cover just to press down on the ram board, not loads of pressure but enough to connect it properly.
Do it at your own risk though.
Posted on Feb 22, 2012
Testimonial: "thanks will try later,,, "
SOURCE: Can't upgrade to 2GB RAM
I just installed 2 1gb chips in my mt3705 and it works perfect  so it might be a problem with your hardware.
Posted on Oct 03, 2008
  • 2692 Answers
SOURCE: Extensa 4620 memory upgrade
According to the manual up to 4gb on two .soDIMM for model ex4220 only.SO yes. I would  take them back and get one 2Gb strip. Download and read the manual first, in case I missed somethng.
Your User Manual: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/c434e20d60a3befe482573560024cc6e?OpenDocument
Posted on Jan 19, 2009
niteshdude36
  • 50 Answers
SOURCE: change 1gb ram to 2gb ram in laptop
Go to any computer accoseies shope and buy a kingston 2 GB DDR2 ram for your laptop
Posted on Apr 03, 2009
Joed911
  • 4338 Answers
SOURCE: Problem with upgrading my acer extensa 5620z memory to 4GB
The Extensa 5620z comes with 1GB of DDR2 memory. That's two sticks of 512MB. This unit technically supports 4GB; 2 x 2GB modules. However, unless you're running a 64-bit operating system (if you have to ask how you'd know, trust me... you're not) then only about 3GB will be usable. There's no fix for this, it's just a fact. All standard 32-bit operating systems are coded this way
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 24, 2009
  • 4 Answers
SOURCE: Acer Aspire 5601 4GB memory upgrade problem
did you try swapping the order of the memory sticks in the machine? for example, if you put stick 'a' in slot 1, and then put stick 'b' in slot 2, did you reverse it and put stick 'a' in slot 2 and stick 'b' in slot 1? sounds corny but i have fixed many computer memory issues in that way. also - have you verified you did not get a bad memory stick? can you boot (and will the computer recognize) stick 'a', then replace it with stick 'b'? try that and post what you find out here.
Posted on Aug 22, 2009
Testimonial: "Good advice. Thanks."
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Need to upgrade RAM which one would be
it requires DDR2-533 PC2-4200, SODIMM
please take a moment to rate this solution thanks
robert
Sep 04, 2010 | Acer Aspire 1691WLMi PC Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Cpu upgrade options on acer aspire 3660
You can upgrade your machine at your own risk but be certain to use a clean workspace, proper dis assembly instructions and have a grounded wrist-strap. I would make sure you have the latest bios for your machine and any firmware updates applied as well for the other devices in your machine.
Check out this thread as some have put a Dual-Core cpu in this machine.
http://forum.notebookreview.com/showthread.php?t=328258
This guy seems to think that the Acer Aspire 3660 is a POS, LOL.
http://davidtrento.blogspot.com/2008/01/acer-aspire-3660.html
Mar 11, 2010 | Acer Computers & Internet
Rebuilding Acer Aspire 3660
Acer Aspire (NoteBook) 3660 Series
Please see below for the Memory ( RAM ) upgrade options available for the Acer Aspire (NoteBook) 3660 Series.
Memory Details for the Acer Aspire (NoteBook) 3660 Series Standard Memory : 512MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 667MHz (PC2-5300) 200-PIN SODIMM
Dec 28, 2009 | Computers & Internet
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Jan 19, 2009 | Acer Extensa 4620 Notebook
Computers & Internet Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
