When i chose the general mode and activates it says insert simcard
SOURCE: nokia n72
I had a similar problem on 2 of my previous nokias. Usually if u take the sim card out and put it back in, and make sure it's all the way in then it's usually fine...at least for a while; but u should be able to call ur cell provider and talk to tech support explaining the issue and i think if you've had the phone less than a year it's still under manufacture warrenty and they'll do a phone exchange with u, sending u a new phone. Hope this helps, good luck.
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
SOURCE: nokia n70 start up sim card not valid
check ur phone IMEI no. (*#06#) if this ??????????????4 then go to nokia care and reinstall IMEI no. OK
SOURCE: N95 on offline mode, not coming in general or
hi malik, you're still having the same problem though, now you know that your phone has the error..
try these steps on your N95 phone.
1. on your keypad, press *#7370# for soft reset
2. then, insert your sim back, check if your sim has been recognized, if it doesn't do step 3,
3. on your keypad, press *#7780# for hard reset once finished, insert your sim back and switch on. if the phone still doesn't recognized the sim, then do step 4.
4. on your keypad press *, 3, call key and power switch at the same time, to make a hard formatting on your phone and setting it back to its factory setting.
>> under above steps, you need to make sure that, battery is fully charge, if not, fully charge battery before doing all the steps above. don't forget to remove your sim every time you do the steps (so as the sd card if your phone has it).
>>>please make a note that, if all of the above steps has failed,or nothing happened and still you have the same issue, then go now to a phone repair shop and have them check your phone, it can be a hardware problem. if your phone is still under warranty, try not to do the steps above, instead, go back to that phone store and return your phone and show them your problem, so they can immediately replace it.
>>>also, make sure that your phone is network unlock and can be use with other network sim.
good luck.
SOURCE: my n70 is going offline
when it turns of in offline mode, turn it off again everytime.
after few times, it should ask you before the logo shows up "DO YOU WANT TO CONTINUE IN OFFLINE MODE?"
SELECT NO, AND VIOLA. ITS IN GENERAL MODE
