Question about Nintendo 3ds Handheld Game Console- Cosmo Black for DS
My 3d ds wont switch on
Orange power light comes on then after a few seconds switches off. Ds will not charge
  • fiona Feb 22, 2012
    ds was not dropped.orange charge light appears for a few seconds then goes off.even while still plugged in the ds will not switch on.could this be a faulty power button.ds is is not under guarantee as cannot find the reciept
SOURCE: my ds wont read any ds card
hi , im sorry 2 hear that would u need to do is take the game card out gently (and i mean gently)
blow into the ds and the see if that works if it doesnt please dont panic just try again or take the
ds card out and look and see if there something on it and if that does not work take back the (or game)
back to the store u got it for and ask for a new one
I hope this works
Posted on Mar 13, 2009
  • 8 Answers
SOURCE: mario 64 ds
stand at the center of the front of the inside of the castle where there is a depression in the ground and look into the light, you will find yourself flying and mustgo down to the tower in the middle and press the button there (must be Mario)
Posted on Apr 03, 2009
aparsons89
  • 40 Answers
SOURCE: downloaded ds games onto sd card. did work on ds
First have you determined if you exceeded the Memory Capacity for the SD card? If so load SD into your computer Memory card Reader slot, It should pop up on the Screen. Look for Options to View, or Edit the SD card, you should be able to open the Memory stuff and delete some of the games. It sounds like you overloaded the Memory Card.
Posted on May 10, 2009
  • 56 Answers
SOURCE: Orange light briefly comes on and DS does not charge
is the charger socket ok as i understand they snap internaly also could be worth checking the battery.
Posted on Jun 27, 2009
SOURCE: Nintendo ds orange charge light flicker on then off . no power when try to switch on
i also had same problem and gameathlon solved it wow you can buy it here http://www.gameathlon.com/advanced_search_result.php?keywords=Nintendo+ds+battery&x=0&y=0
Posted on Jul 14, 2009
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
My nintendo ds lite wont power on
Bring it to a repair shop or buy a new one.
Jun 19, 2012 | Nintendo DS Lite Console
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
check battery,check fuse in power suply section
Sep 06, 2009 | Nintendo DS Lite Console
It wont turn no matter how long i charge it
does the orange light flash of a few seconds after you plug it in? If it does, I think that it is a battery problem. After a lot of charges, the battery's capacity decreases. If the orange light just flashes, I would try a new battery http://www.nintendorepairshop.com/shopdisplayproducts.asp?id=191&cat=Nintendo+DS+Lite+Batteries for ds lite battery or http://www.nintendorepairshop.com/shopdisplayproducts.asp?id=188&cat=Nintendo+DS+Batteries for a ds battery (both $8)
Jul 15, 2009 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Beyond Repair?
I would try and get a new DS if I was u
Jan 04, 2008 | Nintendo DS Lite Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Nintendo 3ds Handheld Game Console- Cosmo Black for DS Logo
241 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
