Question about Braun Health & Beauty
Braun shaver 340s-4 Does not charge correctly , gets very hot.
Only 2 months old, red light flashes after long charge
SOURCE: Braun 5520 Shaver Stopped Working
order a replacement 5520 PCB assembly. it is very easy to replace. remove the two bottom cover next to the charger and remove the two screws. slide the unit out and pop off the black plastic cover. remove the defective PCB battery module and insert the new one. replace the black plastic cover and slide the shaver back into the shell. charge annd it ready to go.
Posted on Dec 17, 2007
SOURCE: red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Posted on Feb 06, 2009
VtToolMan
  • 704 Answers
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
Testimonial: "very helpful"
brector3
  • 1623 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
brector3
  • 1623 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
Red flash won't charge
If we knew the make and model of the camera equipment you are using, we could attempt to offer a solution.
Jun 07, 2017 | Cameras
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Raggta 6 scooter not been used for 12 month,red light on charger flashing all time
A flashing red light orLED on most mobility scooter chargers means the Batteries have a defect as mostchargers also test the condition of the batteries. This has happen becausemobility scooters batteries loose charge when not in use, and need a maintenancecharge at least once a month (best once a week). If this is not done batterieswill fail! Get the batteries load tested to confirm that they are faulty,
Oct 26, 2011 | Health & Beauty
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
My xbox is messed up
if they are red, your hard drive or other hardware is damaged, and requires a repair or replacement free of charge if under 12 months old
Aug 24, 2008 | Microsoft Xbox 360 Console
Sony ericsson w580i
the EROM file on your phone is corrupted that is why it just flashes red and not boot-up, you need to have the EROM reflash for the phone to work again.
Jun 18, 2008 | Sony Ericsson W850i Cellular Phone
W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Mar 14, 2008 | Cell Phones
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
Red L.E.D light won't stop flashing
Nov 20, 2007 | Health & Beauty
Health & Beauty Logo
233 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
