Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Philips 51PP9303H17 Convergence Issue
I'm sure you guys here about this all the time, but I want to be clear about my problem before I break out the soldering iron. I'm having a convergence issue, but only with the red color layer. It's warped in more than one corner, and when I went to adjust the Multipoint Convergence the crosshairs themselves were warped both horizontally, and vertically, in more than one place. If it is the convergence IC's could someone point me in the right direction as to where I could find them, and if possible mabey picture of them to verify I'm looking for the correct parts. Any help would be appreciated.
  • Philips Master
  • 3,459 Answers
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 27, 2009
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
Has yellow and blue and numbers and words are double
You probably got a convergence issue. What that is is when the RGB is out of allignment witch causes one color to show more the an other or vice versa. You going to have to have a repair guy come out and look at it.
Thanks hope this helps.
Apr 23, 2010 | Philips 60PP9401 60" Rear Projection...
What does an ssm board for a philips 51pp9303h17
The ssm is very exspensive at least 250-350 but it sounds like you only need the convergence repair kit. You can get the DPTV305-DPTV345 convergence repair kit from www.tvrepairworld.com which also contains the Cd with instructions.
Jan 13, 2010 | Philips 51PP9303H Rear Projection...
I have a philips projection tv, there is a green hald circle at the bottom of the screen also the picture has double images and very yellow and red. I just bought this from someone who keeps telling me its...
It sounds like multiple problems. First of all these sets are famous for bad coolant between the tubes and lenses causing the picture to be degraded causing the foggy picture. The fluid can be changed to clear up the halo's. The double images are convergence issues. Most likely both convergence amps need to be replaced. I hate to say it but it sounds like you got a money pit. Good luck. Thanks for using fixya.
Dec 21, 2009 | Philips Televison & Video
03 philps 52' rear projection red and green lines laping?
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Strange convergence problem on my Philips projection TV
The only real test is to try to adjust the convergence for each color...Red and Blue...If you cant move both colors in all directions - up - down - left - right...then your Tv has a convergence problem. Try in both 480 and 1080...if it can't be adjusted - replace the parts. I just did mine the other day
Jul 28, 2009 | Philips Televison & Video
Adjusting the blue convergence on tv
1st. Go back over your soldering and make sure you didn't break a trace and joints are solid.
2nd. Make sure you installed the correct value resistors in there places.
3rd. I believe the blue crt is on your right, follow the convergence leads down to the board to the 4pin plug. Go from pin 1 of the plug to pin 11 on each of the IC's ( 1at a time ) with an ohm meter, when you see 0 or just about 0 that will be the blue IC, I have the PTV 915 manual that i'm using. I suspect you will find a mistake along the way. Take your time and double check everything again and let me know. Good Luck!
Feb 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 60pw9363 convergence issue
there is a convergence repair kit for ypour model which has both convergence ICs and all 12 Feed resistors at the following link. They also include step by step instructions with pictures of how to do the repair. Heres the kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 03, 2009 | Philips 60PW9363 60" Rear Projection...
Philips Projection model #51PP9303H17 AV5 input not working?
After many hours of research, I was able to fix the missing AV5 channel. I had to access the service menu using code 062596 and the Status/Info button on the Philips remote. There was an error message that had to be cleared and then AV5 needed to be turned on in the options menu. While I was in there, I also turned on the WSCR option, giving me two additional wide screen aspect settings that had also disappeared. I advise you not to go into the service menu unless you do your homework and document each setting before you make changes. Good Luck!
Nov 29, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
