Question about Genie Company Televison & Video
Older 1970;s Genie model 450 garage door opener.
The garage door opener is 1970's model 450
SOURCE: Reprogramming a Genie garage door receiver
I ned a akai audio timer DT-100
Posted on Aug 18, 2009
SOURCE: I need to replace the battery on a Genie GICT-390
If its a lighter grey colored intellicode remote: There should be a small slot on the side of the remote. Use a coin such as a dime or a penny, stick it in the slot and twist. The remote should split in half and you'll see the coin-shaped battery. After you replace the battery, you can snap the 2 pieces of the remote back together.
If its a dark grey/black intellicode remote: The back cover should partially flip open to reveal the battery. This remote takes a 12volt N-size battery.
If its a keypad remote you are referring to: The bottom half of the keypad's face should slide straight down to reveal the battery (you should see and arrow and some thumb grips). All Genie keypads take 9volt batteries. Source(s): I am a genie technician
Posted on Nov 20, 2009
blanchettohd
  • 143 Answers
SOURCE: Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
Posted on Jun 06, 2010
blanchettohd
  • 143 Answers
SOURCE: how to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Posted on Nov 06, 2010
  • 13433 Answers
SOURCE: I have a Genie garage
Unfortunately the device pairs itself with the receiver with its own identifier, both remotes would need to have the same identifier or code that is sent to the receiver for it to accept both, right now the other is giving out a different signal, maybe you can take the remotes apart and see if there are switches inside that define its code, once both devices send the same code they will work at the same time.
but right now as both devices have their own code it will not work.
there might be no way for you to change it, you are pretty much on your own on this one.
Craftsman Door Opener Model #139 53975SRT1 1/2 HP will not open the garage door. It will close it. And if it's on the way down and I hit enter, it will open mid stream. But, if it's closed, an
Two things. Check for a broken door spring. If okay, remove the cover from the motor housing and check for a bad drive gear. This is a white nylon gear just in front of the motor. If it is going bad it should be obvious.
Jul 05, 2012 | Sears Craftsman LiftMaster Chamberlain...
Keyless pad will not communicate with reseiver
Are you sure you purchased the right keypad? The model you should have is 139.53681
May 03, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door senser not working
What doesn't the sensor do with an obstacle?
Feb 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
The garage door opener inside the garage doesn't open or close the garage door. How do I diagnose? The model # is: 41A5389-1B
The model number you give is a part number for the logic board. Does your remotes work? Is it only the wall control that isn't working?
Sep 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
I need the receiver and garage door control button for a NuTone Garage Door Opener Model GB575, GB580 & GB580-8
I think you will need to check into a Sears Model #00953751000 or Chamberlain Model #R39663 universal remote control replacement kit.
Apr 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
976 people viewed this question
Top Genie Company Televison & Video Experts
Dan Apthorp
Leonard Manamela
Leonard Manamela
Are you a Genie Company Televison and Video Expert? Answer questions, earn points and help others
