Question about Radio Shack Pro-96 Scanner
Will scan but won't pickup transmissions
I can program in frequencies but it won't pick-up transmissions not even the weather channels.
SOURCE: My Pro-96 Suddenly Doesn't Pick Up Transmissions
I have had the same problem occasionally, and I figured it out pretty much by accident. If you inadvertantly hit the ATT button while scanning, it will turn on the attenuator?. This will usually drastically reduce if not stop completely the receiving of signals normally.
Manually go through each frequency looking for the "A" to display on the top line of the display. If it shows up on a channel, hit the ATT key and turn it off.
If one of your data channels had the attenuator turned on, You problably will not receive anything at all. Give it a try.
Posted on Feb 15, 2008
Joe_Rex
  • 114 Answers
SOURCE: Scanning problem
i HAD THE SAME PROBLEM AND HAD TO GO TO ONE CHANNEL AT ATIME IN MANUAL AND HIT THE PROGRAM BUTTON TO RESET IT TO MEMEORY. YOU CAN TELL IF IT IS THE PROBLEM IF YOUR SCREEN READS "ALL CHANNELS LOCKED-OUT"
Posted on Jun 22, 2007
SOURCE: Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Posted on Mar 28, 2008
BillB-SA
  • 2761 Answers
SOURCE: Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on Feb 24, 2010
  • 3741 Answers
SOURCE: i have programmed my pro164
you will have to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the www.starrsoft.com website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ .
but if you have tried doing this.i advise do it again.again run the program by connecting the cable again.if you have not tried it then do it again. if still the same problem.then it might be the problem with the scanner.get it rechecked from radio shack. there are many many users facing this same problem this particular model of radioshack scanner and other model in which this same problem occurs is pro-197. get it checked with radio shack.tech. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Mar 27, 2010
Run channel auto scan
The auto scan feature scans the various channel frequencies looking for a signal. Weak signals may be picked up on one scan and missed on the next. Check your antenna or add a antenna power booster and try again.
Sep 18, 2013 | Sony BRAVIA Televison & Video
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
My Sanyo TV won't scan every channels that my other TV's scan!
check weather some of your channel was deleted in the program. just add those channel so you can make auto scan programs.
Oct 07, 2012 | Sanyo DP46849 46 in. HDTV
My uniden bearcat 50 channel 800mhz stop the police,fire ect.. and only gives me weather.. why? can you help ?
  • You can try pressing "Manual" and then "Scan" or "Band" buttons from the weather setting to get you back to scanning the police, fire,etc.
  • Make sure you don't have a WX (Weather) frequency programmed into on of the regular 50 channels or the scanner will continue to stop every time around as it will pick up the WX frequency.
  • Make sure you have your scanner programmed as well.
Regards, Tony
May 27, 2011 | Uniden BC80XLT Handheld Scanner
Sony Bravia Digital TV won't tune Channels 350 and 350, can't manual tune wither as it will only accept 2 digit numbers, even though it tunes 201 ...
These numbers are the LCN (Logical Channel Number) assigned by the broadcasters. It will only be at 350 if it is the same channel from a different transmitter. You need to know the 'channel' of the frequency to manually tune it in. You are talking about the program number not the channel (frequency), a common mistake. i.e ABC in Sydney is transmitted on CH12 (226.5Mhz) and the LCN's for each program are 2,21,22,23,24,201 & 201. If your antenna also picks up the signals from the Kings Cross transmitter ABC is CH30 (543.5Mhz), as these are later in the spectrum they are put in the LCN list starting at 350.
May 10, 2011 | Televison & Video
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Jul 08, 2010 | Radio Shack Pro-82 Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
Bill B
Nov 02, 2009 | Radio Shack Pro-82 Scanner
Programming the BC244CLT
Hi, If I'm reading correctly, that scanner is listed as a 30 channel scanner only. You can pick freq's from 10 different bands. Here's just some of the features listed, hope this answered your question.
Mechanic
FEATURES:
  • Clock/Alarm - Large backlit LCD displays time and features "any button" snooze.
  • 30 Channels - You can program each of these memory channels to store one frequency.
  • 10 Bands - Including all public service bands, 4 "HAM" bands, federal and military land mobile bands.
  • Weather Scan - Automatically scans all national weather service frequencies.
Jan 17, 2008 | Uniden BC244CLT Base Scanner
Radio Shack Pro-96 Scanner Logo
178 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
