Question about Samsung 933HD 19 in. LCD TV
Samsung 933hd sky remote code
The code for the samsung 933hd for skt digital is 0646
  • 44 Answers
SOURCE: samsung plasma tv
Samsung codes for sky reomte 0060 065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
Posted on Jan 21, 2008
chain saw
  • 94 Answers
SOURCE: My sky remote has stopped working on my samsung tv
PHONE UP SKY FOR THE CODES..THEY WILL HELP YOU OVER THE PHONE.. HAVE THE MAKE AND MODEL OF YOUR TV TO HAND....
Posted on Mar 10, 2009
  • 37 Answers
SOURCE: what is the sky remote code?
These codes are for Samsung, one of them will work: 065, 584, 037, 245, 476, 398, 516, 292, 318, 037
Hope this helps
Posted on Mar 22, 2010
  • 524 Answers
SOURCE: what is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Posted on Jul 27, 2010
SOURCE: i have a samsung le32c530
1340 works for this model.
Posted on Jun 15, 2011
I need a code for my Samsung tv model LE37A456C2DXXU, to connect my Sky remote to the television. Thankyou.
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
Try the codes above and report back.
Oct 16, 2010 | Samsung TV Set Top Box Remote Control
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
4 digits: 1340
Thanx
Jul 27, 2010 | Samsung Televison & Video
Hi there i need code for sky remote to pair up to samsung lcd tv model number LE40b652,have tried 0060 in the book but not working sky bloke said that there is a tv model number code
if you look inside the battery compartment there should be a revision number for the remote.
for a LE40b652 use -
Rev 4 or 6 Remote - 0646 or 0502 or 0615
Rev 8 Remote - 0646 or 0840 or 1340
Feb 28, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
I need tv code for samsung le32r51bd. so i can enter it into sky remote control.
Sky HD Code is 1340 to enter it: -
Press TV
Hold down Select and Red Button at same time until Red LED flashes twice
Press 1340
Press Select and the Red LED will flash twice to confirm that it has been set up.
Now press the Power Button to confirm that it operates properly.
May 08, 2009 | Televison & Video
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Sky remote tune to samsung
3. Press tv again
Samsung Code: 0060
Aug 13, 2008 | Samsung WS32Z308P 32" TV
Samsung plasma tv
037
Jan 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
Samsung 933HD 19 in. LCD TV Logo
107 people viewed this question
Henry  Thomas
Henry Thomas
