Question about E-Machines eMachines Desktop PC
Emachine doesn't recognize the ethernet cord when plugged in
I hooked up the ethernet cord to computer and it still says cable unhooked i know the cables are good, i have 2 and they both work on my laptop. wierd
  • Kathy Feb 20, 2012
    i bought a used computer, hoping i could restore-reformat it. I have all the cd
    s to it, but when i connected the ethernet cord, it still tells me that a cable is unhooked and will not get online.
  • Kathy Feb 22, 2012
    I will check that today, thanks for your help :)
  • 669 Answers
Sounds like the integrated ethernet port has gone bad. You can install a new ethernet card in one of the PCI expantion slots. Then plug the ethernet into the new card, this should take care of the problem. You can not repair a bad integrated ethernet port.
Posted on Feb 20, 2012
2 Suggested Answers
  • 100 Answers
SOURCE: need to burn iso file but acer emachines d725
Installing the nero saoftware
Posted on Sep 25, 2011
My computer doesn't recognize my printer
It's possible that the problem is with the USB port on the printer. If you have a router, you can try to connect your printer using an ethernet cable so you won't have to configure your printer using a USB cable.
Once you have connected the printer using an ethernet cable, proceed with the installation in your computer and choose ethernet as the connection type. It should automatically find the printer on your network.
Dec 08, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Whenever I plug my ethernet cord into the modem and into my computer the internet still doesn't work
you might wanna check if the ethernet cord that you are using is working properly Internet light as well should be lit up on the RCA modem box.
Adriambo Tambuyat
Sep 08, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I just moved in to my college dorm yesterday and you have to use an ethernet cord for internet in my room. So I bought one, and when I plug it into the wall and into my computer, the ethernet port has a...
The lights means the port is active and working. Does the lan connection show as connected on the computer, what IP are you getting if any? Does the college use a proxy?
Aug 30, 2011 | Toshiba Ethernet Cable (cmcable)
My modem is working correctly. My wireless router is working, but my laptop doesn't recognize my modem; therefore, I cannot access the internet. I can if I plug the Ethernet cord into my laptop.
There's a lot of layers to what can go wrong, generally speaking you should be able to get online if two conditions are met: You are connected to your wireless network, and your modem is assigning an IP address to your router.
Once you know you are connected to your wireless network (you should be able to see the correct network name when you put your mouse over the computer icon in the lower right - assuming you are using Windows), you can generally fix most situations where the modem is not assigning the router an IP address by resetting the devices in the proper order, here's how:
1. Unplug the power cord from both the modem and the router
2. Wait 1 full minute
3. Plug the power back in on the modem
4. Wait for the Cable light to go solid
5. Plug the power back in on the router
This will solve the vast majority of issues. If it does not, double check to make sure the ethernet cord from the modem is going into the proper plug on the router. Usually this is going to be labeled "Internet", "Modem", or "WAN", in stead of a number.
If even this does not resolve the issue, feel free to give your ISP a call. While this may be a problem with the router, most ISP employees are at least willing to do minor preliminary troubleshooting, and will often have access to advanced tools to help them see what the modem can see.
Aug 12, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
No internet or lan lights on? Tried reset, hard reset. All other lights, power, wireless, router are on and green. No lights on internet and lan connection. I have tried another wireless router and have no...
The LAN lights will only turn on once you have an Ethernet cable connected to it and the other end of the cable is connected to a working computer.
If you already have a computer connected to the Ethernet port of the router via an Ethernet cable and the lights are still off. Check if the computer you have connected recognizes a network via LAN.
If the lights on the router are still off and the computer doesn't recognize a network then that means that the port for the ethernet of your Router is bad and sadly there's no way of getting that fixed but to have the router replaced.
Otherwise if the lights are off and the computer recognizes the Network and lets you connect to the internet or other computers on the same network then its just the LED of the LAN light that's broken and I think you can live with that.
Hope this helps!
Jul 18, 2011 | Buffalo Technology AirStation Nfiniti...
The router doesn't recognize the dsl modem. I have hooked up to the internet directly from the computer and modem-no problem using the same cable the router can't connect to the...
connect the Ethernet Cable to lan Port and make new connection from Window (PC also should connect to the Lan Port) and configure the username and Password (test it ) if it is going this mean the Wan Port Has some Problems......
Jul 12, 2011 | Computers & Internet
I need to lock my router from others using my wifi
    • 1 Disconnect the power cord from your high-speed modem. Locate the Ethernet port on the back of your modem. If an Ethernet cable is already plugged in, trace the cable to the second device and unplug the cable from it; otherwise, plug one end of an Ethernet cable to the open Ethernet port on your modem.
    • 2 Plug the unused end of the Ethernet cable to the port on the back of the router labeled "modem." Plug a second Ethernet cable into one of the open ports located above the "modem" port; connect this cable to the Ethernet port on your computer.
    • 3 Reconnect the power cord to your modem; wait for the lights on the front panel to turn green before proceeding. Plug one end of the router's power cord into the corresponding port on the back of the device; plug the remaining end into any available electrical outlet.
    • 4 Turn on your computer and log into your operating system as normal. Insert the installation CD into the computer; the installation application should load automatically (if it doesn't, you can find the application by manually browsing the CD's contents).
    • 5 Follow the onscreen instructions; after you have made the initial configurations, click on the option labeled "Security Assistant" on the left side of the installer window. Select the desired security type for your wireless network and click on the button labeled "Next."
    • 6 Choose a network key and enter it into the appropriate field; press "Next" and follow the onscreen instructions.
    • 7 Open your computer's wireless network settings and enter the wireless network name, security type and network key into the appropriate fields. Save your changes. Set-up is now complete.
Tips & Warnings
  • You can access additional settings via the modem's manual configuration interface. Open your web browser and navigate to 192.168.2.1; when prompted for a password, leave the field blank, and click on the button labeled "Submit."For optimal signal strength, choose a location for your router that will be near your computer, with as few walls and other obstacles as possible.
Read more: How to Set Up a Belkin N F5D8236-4 Wireless Router ' eHow.com http://www.ehow.com/how_5106168_set-belkin-fd-wireless-router.html#ixzz1ONVtjSQ1
Jun 05, 2011 | Belkin F5D8236-4 Router
Not recognizing connection
Not sure on the configuration of this model, but is there a port on it labelled WAN? If so your cable from the internet should be plugged into this one and all other cables go into the other ports.
Oct 14, 2009 | Linksys 4-port Wired Router (NR041WM)
I dont know how to set up my routers
Put the setup disk in your computer and it will step you through the process.
Typically, you will have to hook your computer directly to an internet connection (with ethernet cable), then unhook it and connect the internet cable to the router (usually in port 1), then connect an ethernet cable from the router to your computer and plug in the router.
The disk should download the appropriate software and walk you through setting up a password and stuff.
After all that, you can unhook your computer and use it wirelessly.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Westell 6100 ethernet
the prob may b with the ethernet adapter on the computer or the ethernet port on the modem or the ethernet cable.....
to check ethernetadaptor  ping 127.0.0.1
to check the ethernet port on the modem...if u plugin the cable u should have a light lid up on the modem ..
to check the ethernet cable  try with an alt cable which is proved to be working
Jul 26, 2008 | Westell Wirespeed LiteLine 6100...
E-Machines eMachines Desktop PC Logo
181 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
