Can connect iPad and Mac Powerbook laptop to my Sony 36
Using Mac adapters and s-video cables (into the s-video 'IN' on the back of the TV), I can hook up my iPad 2 and Mac Powerbook laptop, but cannot get either to project onto my tv using any and all Video channels. I've tried shutting off my cable box, every combination of everything, and still can't get it to project. I can see a distorted view of my iPad desktop on Video channel 2, but that's about as close as I can get. I have successfully projected using wall projectors on both devices, so can't figure this out. Is my TV too old to do this?
  • 739 Answers
Hi Jim
It's not on a channel, it's the RGB or VGA inputs. (check your "Source" menu on the TV). Works fine here. When the units are talking to the TV the screen on the unit will go blank. One thing. When using your iPad, tghe battery will go down faster than normal.
Posted on Feb 23, 2012
2 Suggested Answers
seaniepie
  • 250 Answers
SOURCE: colors on Mac G4 Powerbook display are severely distorted
Hi
Goto Apple>SystemPreferences>
in the System section choose UniveralAccess>Seeing and make sure it says Black on White is selected, that Use Grayscale is unchecked and contrast is set to Normal.
If it's not that then its your display and needs a service.
All the best
Sean
PiDigital
Posted on Dec 16, 2008
Ive recently bought a second hand Sony Cineza VPL-HS2 projector and it doesnt have an AVG input in the back. It does have a S-Video input, a 'video' input and a couple of audio inputs,
I think you mean "VGA" not "AVG". You can use the VGA to S-Video adapter to connect the laptop to the projector however you may get better results using a VGA to A/V (component) adapter to feed video into the RCA video input connector.
Nov 20, 2014 | Sony Cineza VPL HS2 Multimedia Projector
Lg smart tv
G$ powerbook will have a high-density video connector providing (usually) VGA and DVI,
All you have to do is to choose the relevant adapter and connect the two units together with a suitable lead.
Jan 24, 2014 | Apple PowerBook G4 Mac Notebook
What is the little button thing with a lock beside the power adapter port
It could be the security slot where you can connect a security cable to stop the powerbook from being stolen.
Feb 26, 2012 | Apple PowerBook G4 Mac Notebook
Yellow vertical lines on powerbook g4
Never a good sign.... usually means that your video adapter is shot.
Most laptop video is built on the motherboard, so that would entail the entire motherboard being replaced. Any chance it is still under warranty???
One other thing it could be... do the lines chnage at all when you tilt the screen back and forth? If so, it might be a loose connection between the moterboard and the monitor. That would be significantly cheaper to fix!
Oct 15, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Cannot connect to the internet
how are you trying to connect it? if you have wired internet, just plug the LAN cable at the RJ-45 LAN port of your laptop and you will be connected. You must have set your LAN Adapter to get IP Address automatically. Also, if you have a wireless network adapter, if you set it up to get IP address automatically, you can connect to available wifi zone.
Sep 15, 2009 | Apple Powerbook G4 15" Screen Mac...
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
SO, ON WITH THE QUESTION PLEASE!!
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
S-video, a laptop and a vcr
What is the camera model, actual powerbook and vcr? And you want to do this to convert from vhs to mini dv? Your camera should have a firewire port on it called 1394. Your VCR may or may not have S-video. If not you can purchase a s-video to coax adapter ( velloy video rca ). You may also need to locate a 4pin to 6 pin firewire cable. the 4 pin is for the cam, 6 pin is for the mac. The camera then goes s-video to rca to the vcr posssibly. Again I am only suggesting this at first, guess what is standard, and what I have seen. Any other variables or specifics that I am not aware of in your case, may change this configuration. If you have Ilife 05 or later or Imovie. Plug the camera to its power source. If the firewire cable is running to the mac, and the mac it on. Turning on the camrea will automatically open Imovie. From there you can load all of the video onto the Macintosh, and do what you like, watch , edit....what have you.
Keith
Jul 10, 2008 | Apple PowerBook G4 Mac Notebook
Connecting Powerbook G4 to Sharp Aquos LC-20D10-W
A few tries, go to the apple in the top left and choose SYSTEM PREFERENCES....it should bring you to:
In the HARDWARE row you should see DISPLAYS. Select that and you will be at:
You have the DETECT DISPLAYS button, and also CLICK the "Show displays in menu bar" box, so you dont have to keep going through menus to configure.
If you look at the F7 key, to the right of the NUM LOCK key (F6), that key allows you to switch from expanded to mirroring or vice versa.
You can also check Apple's Knowledge base....
http://docs.info.apple.com/article.html?artnum=58620
Keep me posted.
Dec 10, 2007 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
