Question about Refrigerators
Change in the drip pan Haier Mod. RRTG18PABW - Refrigerators
4 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Can't find the drip pan
Please tell me whats the type of refrigirator you have. If its a frost free then the drip pan , in most cases will be at the bottom of the refrigerator. If it is not accessible then you may need to empty your fridge and lean it against a support to access it. If you can specify the make and model I can offer you more specific advice.
Posted on May 26, 2009
heatman101
  • 43501 Answers
SOURCE: drip pan constantly filling up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 21, 2010
TheMobilian
  • 8220 Answers
SOURCE: cant find drip pan for haier refrig.top freezer. model#rrtg21pabb any suggestions
http://service.haieramerica.com/Models.aspx?CID=3131
Now let us look at the diagram:
RF-5150-01 is the part number
My Haier LINK
$23
Posted on Nov 04, 2011
Where is the drain plug for a Haier 24,000 unit? The water is dripping in my house.
Its probably leaking due to the drains outlet is stopped up. Shouldn't be a plug in it. At the bottom of the indoor coil there is a pan that catches the condensation. Its probably Styrofoam. The drain opening are commonly on the right side but not viable from the front. If possible, the housing can be removed to see the opening/very small. Or, with the unit pulled from the window, spray the coil and pan at the bottom to try and clear the opening spraying through the coil. You can also use cpmpressed air to blow through the bottom of coil where the coil sits in pan. This might get messy if the unit is still in place. The opening for drain is about the size of a drinking straw. Good luck!
Aug 13, 2015 | Haier Heating & Cooling
What is the red light that flashes and won't let it come on
Hello. Surprisingly, I had that very problem happen to me with my Haier AC this morning. The machine is telling you that your 'drip pan' is full. If the A/C kept running it would overflow the drip pan and will get the water all over your floor. Very easy solution. In the back center of your machine just above the floor is a black plug. When you pull the plug out, water will come out, so before you do so, get a shallow pan (I used a lunch tray) and put it underneath. The plug isnt threaded, just pull and twist to get it out. The amount of water that will come out is significant but doesnt come close to filling a lunch tray. Once drained just put the plug back in securely and turn on your AC and you're good to go.
Jun 19, 2014 | Haier Heating & Cooling
I have a Haier Air Conditioner window unit that is leaking inside the house. What are some possible causes and solutions?
There are basically 2 causes:
1. The rear of the AC unit is not tilted down enough, so that water in the drip pan flows to the drain hole in the rear of the drip pan. The general rule of thumb for rear downward titl is 1/4" to 1/2".
2. The drain hole in the drip pan, near the rear of the unit is clogged. Locating the clogged hole can be a challenge, as the clog will blend in with the drain hole. Patience & persistence are needed in locating it. A pipe cleaner works well to clear the clog from the hole.
Hope this helps you and thanks for choosing FixYa.
Aug 17, 2011 | Haier (HPE09XC6) Air Conditioner
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
Haier Model# HWF05XCK-L 5000 BTU window air conditioner is leaking underneath and spitting water out of the top. It was installed as recommended.
The problem you're experiencing is generally caused by the rear of the unit not being tilted down enough. 1/4" to 1/2" is the general rule. This allows collected water in the drip pan, to run to the rear of the unit, where the drain hole is located. It would also be prudent, to check the drain hole under the drip pan, to see if it's clogged. It can be cleared with a pipe cleaner.
Jul 27, 2011 | Haier Heating & Cooling
My Haier window ac unit is dripping a lot of water into my room. It only starts to do it after it has been on for 20-30 minutes, but comes out in a steady stream from the bottom of the unit for the rest...
The window unit is most likely not tilted towards the outside so that the condensate (water) can flow to the drains on the outside part of the unit. Try leveling the A/C or even tilting (Slightly) towards the outside. This will cure your problem.
If this does not cure the problem then you will have to remove the a/c from the window/wall and remove the cover. Inside you will see the drip pan in the bottom and will have to clean the water channels the run from the pan to the outside part of the unit, they will be clogged with dirt or debris and not letting the water flow properly.
Hope this helps.
Jun 13, 2011 | Haier HWR06XC7 Air Conditioner
Water drip
The water just drips outside from the back of the pan...make sure it is tipped back towards the outside...
heatman101
Jul 09, 2010 | Haier hwr10xc6 Air Conditioner
May 26, 2009 | Haier Refrigerators
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
