Could i get service manual for Samsung WF-j1061 Washing Machine
Power Lamp not glowing . Wall Socket out put ok Power in all connecters. where it should be./
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Posted on Sep 02, 2008
  • 83 Answers
SOURCE: Dead LG WF-T8016TP washing machine
Is there any other appliance plugged in the same power point, and does it work?
Otherwise, plug another appliance in it to test that the power point is actually working.
If it is not, possibly a fuse has blown or breaker switched off in your meter box outside.
Let me know
Posted on Sep 16, 2008
SOURCE: Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Posted on Nov 11, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
My machine don't want to turn on
You mean the lights do not come on in the machine panel. Power off the machine and remove the plug from the wall. Get another working object like a desk lamp or something to test it in the wall socket you are using for the w.machine. If okay check the plug of the machine.............Usually it is a loose connection............
Mar 07, 2015 | Washing Machines
Samsung WF-R1061 washing machine repeatedly trips
does it show an error code ? when it trips what is the washer doing filling water or spinning etc ? does it work on other settings like spin and drain with out tripping. ?
May 27, 2017 | Washing Machines
Washer does not start, replaced lid switch, and timer still doesn't work. when parts mentioned were replace. washer did start and fill but then stopped.
Hello there and welcome to fixya
I am sorry to hear that you are having problems i will post some information on some more parts that need to be tested ok?
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Sep 24, 2011 | Maytag Washing Machines
Have a GE Select washing machine that won't start or operate ? Can you help ?
Hello there and than you for choosing fixya
Feb 06, 2011 | Washing Machines
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
Operating of samsung WF-B1061 washing machine
You can download the manual direct from samsung just go to their site type in your machine and download.
May 22, 2009 | Samsung WF317AAG Front Load Washer / Dryer
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
