Question about Brother Sewing Machines
Brother XV-1120 Sewing Manual
How to thread a double needle?
  • 3 Answers
SOURCE: I use Brother VX 1120 Sewing Machine. It can not
go to the brother website, you can download and/or look at the manual for free
Posted on Mar 04, 2009
  • 7 Answers
SOURCE: how do you thread a brother pacesetter 6000 for
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
Posted on May 06, 2009
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
SOURCE: Sewing machine bobbin thread issues
i dont found the bobine
Posted on Nov 22, 2009
SOURCE: Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Posted on Oct 30, 2010
How do I reset the timing on my brother vx 1120 model?
Be sure to install a brand new needle.
If it still doesn't work, then search for "sewing machine timing."
Jul 28, 2017 | Brother Sewing Machines
I have a brother vx1100 sewing machine and I forgot how to combine the bobin thread with the upper thread to start sewing please help
ono secret
just pull the bobbin thread down the slot in the bobbin holder and under the spring plate
leave about 6 " thread loose and put the bobbin and holder back in the machine
use you hand and turn the machine over a few times and the needle thread will pull the bobbin thread up
or use a bit of scrap material and start a short sew
Jan 15, 2017 | Brother Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Manual brother vx-1130
Sue, I will post links below for your manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Brother VX 1120 User Manual
Brother VX 1120 Sewing Machine Threading Diagram
Manual BROTHER VX1130 Operating Instructions Service
Brother VX 1120 Sewing Machine Troubleshooting eHow
Mar 03, 2016 | Brother Sewing Machines
Shuttle on a Brother VX-1120 sewing machine will not pick up the bobbin thread
Bobbin in backwards, needle in backwards, needle damaged, needle too small for the thickness of fabric or needle not the correct needle system for the machine are my first guesses. Try a new size 12/80 needle, flat of the needle to the back of the machine, completely up in the needle clamp as a first pass at the problem.
Feb 18, 2014 | Brother Sewing Machines
How do I thread the model 1120 . I can get it threaded until I get to the last step before putting the thread in the needle.
Go to singerco.com and download you manual, you can make the pages nice and big to see the thread path. It is free so, don't worry about that. Good luck & happy sewing
Sep 06, 2010 | Singer 1120 Mechanical Sewing Machine
I have the bobbin threaded and put back into the machine but I can't get the thread from the needle to catch the bobbin thread on a brother vz-1120 machine
Make sure that a new needle is fully inserted up with the flat side to the back.
Unthread the machine. Place the presser foot in the up position, the take -up lever in its highest position and set the tension to 5.
Re-thread the machine and then try to sew.
Jul 19, 2009 | Brother Sewing Machines
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
117 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
