Question about Psion Workabout MX RS232 / TTL
FAILED TO SYNC CLOCK - Psion Workabout MX RS232 / TTL
How do you sync your iphone with the Memorex MA4221 FM Clock Radio for iPod and iPhone
The Memorex is a player only. It does not have the ability to sync, that is, to exchange files with the iPhone. It should be able to play music already saved on the iPhone, however.
Sep 19, 2013 | Memorex MA4221 FM Clock Radio for iPod and...
The clock on my computer is always running slow and I have to regularily alter it.
The only way I can think of to 'fix' a pc clock running slow is to set it to automatically sync with an online clock.
You could try a program like NetTime (Link Here) and have it automatically sync it so it's the correct time.
Apr 17, 2013 | Acer AL Computers & Internet
Radio, CD player, Sync, clock stopped working on my 2008 Ford Explorer
Most likely a fuse. If your fuse box is labeled it will say radio under the fuse. If its not check your owners manual for location of fuse box and radio fuse.
Mar 04, 2013 | Cars & Trucks
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
Im trying to connect two rc-50 via midi! I want one of the them to act as a master and the other one as a slave. The goal is to have both machines working independently but have all loops on each rc-50 to...
While you can probably get the functions sent by MIDI to transfer to the other unit, syncing PROBABLY isn't going to work very well because there is a lag to form the MIDI sync clock (serial data) and then receive it, decode it and do something with it.The transmit time is about 1/3000 of a second and receiving is at least that much time. On rhythm things I have found the ear can hear 1/1000 of a second easily. If one could set the machines to use an EXTERNAL sync clock and drive the SAME clock to both units, you might be able to sync them together time wise as they would see the sync at identical times.
Apr 14, 2011 | Boss Rc 50
The tempo not synchronize with protools and nuendo ?
Search index of the manuals for MIDI sync clock or similar name. Usually you can turn this sync clock on or off.
Jan 03, 2011 | Korg Pa800 Synthesizer
The time and chimes are out of sync for our tempus fugit wall clock by 4 chimes does any know how to adjust it
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Apr 24, 2010 | Seiko Mantel Clock
Sync b/w google talk servers and my comp clock???
Verify the date and time are correct on your system.
This seems to be the number 1 cause for this.
Oct 02, 2009 | Google Talk
Computer clock
u can try using YAHOO WIDGETS from widgets.yahoo.com
u can find lots of clocks that sync with the online server of the widget itself.. in some clocks u can also set a reminder for nething u want.
or u can www.worldtimeserver.com to sync ur windows clock with it. u can find the details of how to sync the clock in the F1 option of ur HP. just press F1 for HELP and type in ur query,it'll guide u with the styeps. if ur using Vista on it then the Vista clock syncs it self with the time server.. u can see it by double clicking the clock in the taskbar at bottom right corner where the clock is.
PLEASE RATE ME,WOULD APPRECIATE IT
Aug 09, 2008 | HP Pavilion dv6000z Notebook
Psion Workabout MX RS232 / TTL Logo
52 people viewed this question
Top Psion Computers & Internet Experts
richie46
ray gallant
Are you a Psion Computer and Internet Expert? Answer questions, earn points and help others
