Wharfedale flat screen tv w42s40pe
When plugged in blue light but no picture. No reaction from menu button on tv.
  • williesmall Feb 20, 2012
    Screen is blank
  • 4 Answers
SOURCE: flat screen trouble
May sound like the video board went out.
Posted on Sep 10, 2008
  • 2336 Answers
SOURCE: Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 20, 2008
  • 6 Answers
SOURCE: no picture
I purchased four 2200uf @ 25v capacitor’s for $8 at that same repair shop. I upgraded to 25v because these will run cooler. The tv came with 10v Samxon caps that seem to be problematic in all the units they were used in. Do not buy Samxon if you do this yourself.... I opened the set by taking off the plastic back panel and then by removing the second metal panel. There are three boards and a hard drive. The board on the far left just above where the plug goes in is the power supply board. There are five data cables and one red power cable attached to it that can be removed simply by unplugging them. The board is fastened to the unit with five small screws, one on each corner and one in the middle of the right side. If you look for three green capacitors grouped together around the middle of the board and slightly off to the right, you will probably see one that is bulging out at the top. This is most likely "C235", the main problem. The other three caps that need replacing are C202, C201 and C219. C219 is closer to the top part of the board.....
The process to replace is simple, believe it or not, and it could save you hundreds of dollars. 1, Go to RadioShack and buy a cheap soldering iron and a small roll of solder. 2, Buy four, 2200uf @ 25v capacitors, online or at an electronics store. 3, Plug the soldering iron in and let it heat up. 4, Locate C235 on the back side of the board and mark the negative terminal with a felt tip marker (you want to make sure that you put the negative terminal on the capacitor through the right hole, otherwise you will pop the cap. The negative terminal is clearly marker on all the capacitors). 5, With needle nose pliers, grip the cap and pull down while heating up the terminals. The cap will eventually come out. 6, Put the new cap in (you may need to heat the solder that is left on the board to clear the hole so it can push through). 6, When both terminals are through, bend them slightly so it stays in place. Take the solder and stretch out a few inches off the roll and while holding it in one hand, lightly touch the base of the terminal where it comes through the board, with the soldering iron and the solder at the same time. --- Try not to use too much solder.. you only need a tiny drop. This will solder the cap in place. 7, cut off the terminals close to the board with some snips and repeat this on the other three. 8, put the board back in, plug in the cables. Test the TV before putting the back panels on. It should work fine if all went well..... If you hear a pop than you reversed the terminals on a capacitor and that one will need to be redone correctly.... This might sound lengthy and potentially difficult but its worth a try. Otherwise you can pay someone to replace the entire board for BIG BUCKS with the same junk caps on it and have the same problem in a year or so. LG doesn’t want to take responsibility for this and I'm sure that it has cost a lot of people a lot of money for about $8 in parts........... This worked for me and it can work for anybody with the same problem.. Good Luck!
Posted on Apr 28, 2009
SOURCE: spectroniq tv flat screen will not turn on, ablue light flashing
HMDI stopped working?!
Posted on Aug 24, 2009
  • 6 Answers
SOURCE: my tv screen just went blank i still get sound but
its the motherboard. i got the same tv with cracked screen. i can sell you the motherboard for cheap or i will buy your lcd to fix mines. if interested email me at quoc5539@msn.com
Posted on Oct 25, 2009
Samsung led tv no picture
What did you do when you say you cleaned the screen? If you shine a flashlight on the screen can you see some very dim picture? If the back light is out. This will require replacing the power board.
Jan 06, 2014 | Televison & Video
I need the USB firmware update utility for a JVC LT-32P679 TV.
my tv won't show a picture the blue light on the bottom left hand corner just keeps blinking
Apr 05, 2011 | JVC Televison & Video
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
Wharfedale LCD3210HDAF blank screen
Wharfedale LCD3210HDAF this tv was working fine the night before .. when i turned it on in the morning the screen came on then instantly went blank .. although the sound is fine i am unable to get any on screen including menu an volume information and of course can any one help ??
Oct 27, 2009 | Televison & Video
Wharfedale 42f1080p faulting?
Replaced any swolen capacitors on the power board.
Sep 01, 2009 | Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
New JVC flat screen cuts off 10 sec. after cutting on
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
Mar 26, 2009 | JVC LT42P789 42 in. LCD TV
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Wharfedale LCD3210AF
dose any 1 now how to fix this problem, i turn on my tv the light is just BLUE, the red light aint showing
Jul 10, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
