Question about Samsung YP-Q2JCB MP3 Player Digital Media Player
My mp3 player keeps freezing
When i go to play music or video my mp3 freezes and i have to press the reset button.-so basically i can't use it for it's actual purpose.-playing music, as as soon as i click on a song it freezes!. But, weirdly the FM radio works and so do the games. Also when i take my mp3 out of the computer after charging it it also freezes.This has been happening about a month after i bought it. HELP?! :(
  • Claire Danes Mar 26, 2012
    helppp me pleassseeee :'( or my mom will KILL me for "breaking it"
  • pangiayang13
    pangiayang13 May 28, 2012
    The same thing is happening for me. The only differences are that I can't download anymore music and when I go to File Browser I can play SOME songs.
4 Suggested Answers
creeperz
  • 52 Answers
SOURCE: Samsung YP-U2 Mp3 Player is not working.
U might have formatted it to NTFS. Convert it to FAT.
Posted on Dec 02, 2007
SOURCE: My Samsung Yp-U3 Freezes Up
the reset button is in the back then it will say reset then use a pin or toothpic and it is that little hole
Posted on Feb 05, 2009
  • 6 Answers
SOURCE: MY PLAYER GOT DRENCHED IN WATER
First. Stop trying to use the unit! Having power go to the unit can and usually will short something out, so if the battery is removable, do so. It may take opening up the machine to find the battery if its built in. I'm not familiar with this one so I don't know.
Next thing I do Is open up the back of the unit allowing air to circulate and giving you access to anything that is moist. At this point, I usually try to use a hair dryer to CAREFULLY dry the interior of the machine. Do this for several minutes as it takes a while to evaporate all the water in the nooks of the machine. Since the machines is semi working, its most likely not that wet. If the machine has been doused, went through the laundry, fell in a toilet, etc, I then choose to re wet the machine my giving it a QUICK dip in rubbing alcohol. The alcohol evaporates quickly and assists in lifting the sometimes contaminated water off the machine. Again, do this once you have nothing to lose.
Go back to blow drying.. 7-10 times, if your patient, dry the machine enough, you will fix your wet item. If its a nice week, allowing the machine to dry in a open window in the sun for 2-4 days cant hurt your chances either.
Just remember, the main damage is caused by shorting out the unit by having it connected to a power supply, this includes the battery.
Unfortunately, this doesn't usually include the lcd screen. they are rather fragile and will usually need to be replaced if there is a dead area once your done.
Good luck.
Posted on May 15, 2009
When I press "Music" on the menu, the unit
Welcome to Fixya. If your player freezes and you already press the reset button it seems that the issue is the you can try to update the software and see if it will fix the issue. Can you provide the operating system of your computer.
Thanks
Jul 19, 2011 | Philips GoGear SA5285/37 Digital Media...
My sansa fuze keeps freezing
Start the sansa updater, set sansa to recovery mode plug into computer. unplug when told sansa should restart (Lock sansa press and hold rec and menu until recovery begins)
Also you can Try
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Nov 02, 2009 | SanDisk Sansa Fuze MP3 Player
My fm radio stopped working on my creative zen vision, and the display is all messed up. It also freezes for about 20 minutes when I turn it on. After 20 minutes, it will play normal, but it freezes...
Support for Zen Vision M on this site:
One of the Knowledgebase Solutions for "freezing" gives this answer:
Solution ID: 64087
dot-clear.gifSolution ID # 64087 -->dot-clear.gifdot-clear.gif -->
Player is Freezing
Keywords / Key Phrases: freeze, freezes, freezing, hang, hanging, freezes at creative logo, at docked screen, rebuilding library screen, playing audio files, switching to other functions or menus while shutting down, freezes at recovery mode, freezing at music playing now screen
  1. Gently push the end of a thin object (such as a pin or straightened paperclip) into the Reset hole.
    The reset button for your player is located at the bottom of the player, to the left of the sync adapter port.
  2. Refer to the article below to access the recovery mode and perform a Clean Up.
    SID 64088: Accessing the Recovery/Rescue Mode of your Player
    Note:
    1. Clean Up scans a player\'s hard disk/memory card and removes any invalid links from the music library. It does not affect the working music files at all. It is recommended that you perform "Clean Up" first before formatting or reloading the player\'s firmware.
    2. It is advisable for you to clean up your player regularly if you are frequently transferring files from you computer to your player or vice versa.
Last updated: June 16th, 2009
Aug 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
MY NW-A1200 MP3 FREEZES AT DISPLAY MESSAGE 'GOOD MUSIC,GOOD DAY'
ı speak turkish no speak english yes problem sony nw a1200 what make sory dont speak english not buy sony nw a1200 help help help
Dec 15, 2008 | Sony Network Walkman NW-A1200 MP3 Player
I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Nov 30, 2008 | Samsung Yepp YP-T7JX MP3 Player
Keeps Freezing
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 04, 2008 | Creative Labs Zen Touch MP3 Player
Freezing
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Jan 06, 2008 | Creative Labs ZEN V Plus MP3 Player
FROZEN songs
reload the latest firmware from · http://us.creative.com/support/downloads/
Nov 12, 2007 | Creative Labs ZEN V Plus MP3 Player
Having trouble with the facet on my mp3 player and trying to get it to play.
idk i have the same problem maybe you should push the reset button.
Aug 04, 2007 | SanDisk Sansa c140 MP3 Player
Samsung YP-Q2JCB MP3 Player Digital Media Player Logo
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
