Question about Samsung Refrigerators
My samsung refrigerator is not cooling, LED light is ON, but motor is not running even i set the thermostat to coldest settings. Its only 3 month old, and very disappointing to encounter such failure at that early.
Rotu
  • 175 Answers
SOURCE: refrigerator not cooling top shelf
it sounds as though you have a fridge that is low on freon. If the ice is appearing mostly to the left, then thats surely your problem. if it goes all the way across, you may have a bad evaporater fan motor, fan motor switch, bad cold control, or just a door that isn't closing or sealing properly. If its the ice mostly to the left side, it probably means your evaporater is leaking the freon. I am assuming you have a model that has a cold control on the back wall, not the electronic display by your description. If your unit is less than 12 years old by the installation date, the part will still be under warranty (sub zero has an unmatched 12 year sealed system parts warranty) but the labor and freon will not be. The repalcement of that evaporater in my area usually runs about $450 with labor, freon and trip all together. It is a repair you cannot do unless you have an acetlyn torch and some silver-soldering/ brazing ability. If your model is in fact the newer style with the electronic temp display, call sub zero up (the # is on the model/serial tag in the door jamb) and tell them wahts going on. If it is in fact an evaporater leaking on this style, they will most likely pay the bill for you even if its well out of the 5 year full warranty. If you want to know for sure, remove all the shelves, then remove the cover over the lights. Then if its electronic remove the 3 screws holding the top of the back panel and tilt the panel out to you and pull it up and out: if its a dial type, remove the 2 screws holding the fan cover and then tilt the back wall out to you and lift it up and outwards, but not too far as it wil pull the wires of that control knob (cold Control) Look at the coils back there and see if the coils are frosty. If they are only frosty on the upper left of the coil, its low on freon and needs an evaporater. if its frosty all the way across, top to bottom, you need a cold control, or possibly a fan or fan switch. Hopefuly you can wade through all this. Just post back if you have any questions. Good Luck!
Posted on Aug 16, 2007
  • 9 Answers
SOURCE: Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Posted on Sep 06, 2008
  • 235 Answers
SOURCE: Fisher and Paykel E522B refrigerator is not
Make sure air circulation is getting to the fridge side . Also check the evaporator fan and see if it is blowing.
Posted on Jul 14, 2009
  • 363 Answers
SOURCE: Refrigerator compartment not cooling properly.
Yes The circulating fan behind the rear freezer wall is waring out. The fan with labor and material cost is around $300.00.
Posted on Jul 26, 2009
  • 286 Answers
SOURCE: Refrigerator compressor motor will not run.
Does the fan work? If yes then the compressor has a relay and overload that might be bad. Or it could be a compressor that is bad. If its a compressor then you will need to have a tech verify that it is the problem. If nothing is running then it could be a thermostat thats not switching it on. Let me know if you need any more help with it.
Posted on Aug 12, 2009
Not cooling sufficently for 3 months and now not cooling at all but light on motor running
check the cold control thermostat. and the several thermistors? as well as the door seals and the air flow control vent and knob setting
Mar 12, 2015 | Refrigerators
Samsung RS2555SL Side by Side Refrigerator
Is the refrigerator still trying to cool as in is the motor still humming? Since many things go wrong, you are going to have to check to see what is still working so that we can narrow it down. This is the first thing that you need to check. Turn it on the coldest setting and see if the motor/pump is still running. Please let me know what you find
May 19, 2008 | Samsung RS2578BB Side by Side Refrigerator
SAMSUNG REFRIGERATOR MODEL RT72KBSL1/2012, IS HAVING TEMPERATURE FLUCTUATIONS. for ex, temp reaches -20 than decreases to 9 degree n again -20 n vice versa. There is fluctuations also on display.
Sounds like your thermostat is sticking on and needs replaced. Before replacing check the setting on the thermostat. Almost all themostats are calibrated to maintain the proper temperature in the correct range when the thermostat is set to the mid position. If your thermostat is number 1 to 9, place it at 5. Refrigerator and freezer do not cool faster setting the controls to the coldest setting. This is misconception of a lot of people.
Sep 29, 2014 | Refrigerators
The fridge to begin with was extremely cold sometimes freezing the food a little even though it was on the lowest setting. 2 months later it has changed and now i have it on the coldest setting and though...
The symptoms are consistent with a bad thermostat. Start with being sure fans Inside and at the Compressor are running and if so replace the thermostat, if the unit still malfunctions, you'd need a refrigeration tech. That altitude won't make any difference. The Salad top units are just fine up to 7000 feet ASL no problem.
Jan 07, 2018 | True TSSU-48-12 Refrigerator Commercial
We have just bought this Refrigerator and when we plugged it to the electrical wall socket, both the fridge and freezer was not cooling, but the inner light was on.Please what was the problem?
Set the temperature control to the coldest
temperature and wait for an hour. The
freezer should get slightly chilled and the
motor should run smoothly.
Jan 02, 2011 | Samsung RS2630SH Side by Side Refrigerator
I've had a Samsung fridge for 6-7 years, it's a small/medium fridge/freezer with the freezer at the top (sorry, don;t have the size handy). The freezer works fine, however the fridge no longer makes...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung Refrigerators
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
