Question about Microsoft Xbox 360 Console
IRQL NOt less or equal ram or motheboard? (or harddrive)
It is not a software problem i have wiped my computer several times and i cannot confirm what it is help please
  • Chris Fritz
    Chris Fritz Oct 27, 2008
    or hard drive( it got cut off)
  • Chris Fritz
    sorry i am under wrong section it is for pc
    Scholar:
  • 159 Answers
It's memory.
Posted on Oct 26, 2009
  • 4 Answers
Asdfasdfasdfasdf sdfjkasd k
lajlkjaskdf
jsakdfj klasd
fasdjfkjasdf
;asdjfkjasdf
as;dfasd
lasdjflsad
f';k
asjdfkjasdklfjkasdjflkas dkfj;saldfjaskdjfklasjdkf
asdfjkasdjkfjaslkdjf
jsdkfj asdjkf
asdjfk asdk
Posted on Oct 27, 2008
Driver Irql not less or equal
You have lost a driver for the program mfewpak.sys or the system driver that is part of this program try this link.
https://www.google.ca/url?sa=t&source=web&rct=j&url=http://www.solvusoft.com/en/files/bsod-blue-screen-error/sys/windows/mcafee-inc/mcafee-total-protection-2011/mfewfpk-sys/&ved=0ahUKEwiBgqPzi8DLAhWMuoMKHbcsC2sQFggdMAE&usg=AFQjCNFDrzTvr_H6PXB1ScO_YdgbbdJVqA&sig2=r1WFj1-LX6CmVymdP3Pbyg
Mar 13, 2016 | HP Pavilion Computers & Internet
Keep getting an error message irql not less or equal and system reboots. what do i do
IRQL errors are generally software/driver induced.
1st see if you can boot to the safe mode (F8 at boot) and get into windows.
If you can try a system restore to before the issue started.
If you can't get into windows, try Fn + power and run diagnostics on the system, you may have a bad hard drive.
Jul 06, 2011 | Dell Inspiron 1525 Notebook
Im trying to reinstall windows on my pc but i keep getting an error message about DRIVER IRQL-NOT EQUAL OR NOT LESS HOW DO I GET AROUND THIS ERROR MESSAGE AND WHAT DOES IT MEAN
check the ff:
1. installer CD
2. IDE/SATA connector
3. Ram deffective / use good one
4. try to use another slot of IDE/SATA in your motherboard
5. defective reader
May 25, 2010 | E-Machines Computers & Internet
(PTZ930AC) Graphic Tablet: I'm getting "driver irql not less or equal" error ...
Guest
If you are getting the "irql_not_less_or_equal" BSOD after the install of the drivers then if is possible that you did not get a clean install of the drivers and/or there is something wrong with the device. To let me better see what is going on I need the stop code. The link below will help you get that info from the BSOD.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Note Window XP 64bit was a transition operating system to help manufactures to write 64bit drivers and software for the 64bit operating systems. However there is alot of products out there that eventhough they have Windows 7/Vista 64bit support they do not have XP 64bit support.
Issken
http://www.fixya.com/users/issken
May 18, 2010 | Wacom (PTZ930AC) Graphic Tablet
COMPUTER CRASHES BLUE SCREEN MESSAGE SAYS IRQL NOT LESS OR EQUAL
reinstall your windows and if the problem still persists, in this case it's a hardware problem
Oct 08, 2009 | HP Computers & Internet
I have a compaq nc6400 gives me blue screen of pfn lis corrupt and irql not less or equal i look up irql not less or equal and it's telling me that it's overheating and that maybe the ram is bad. help me,...
usually blue screen errors are related with the ram memory issues or ...corrupt (bad status) Hdd, but in your case probably one of the coolers doesnt work and it is overheating and forced to shut down suddenly ..,solution is to verify the ram memory ...and check the bios for any temperature limitations...and best is to restore the optimal defaults settings ...( factory defaults ) ...and also try to reinstall the operating system cause it might just have so issues ....also ...try to remove and replace the ram unit in its slot ..to be sure that its all ok ...
there is whatever the possibility that overheating damaged the ram memory already ,.and in this case it should be replaced... but this case its rare ...and ram memory if its not touched by hand ...usually has a life time exploitation period...
so ....either unlimited the maximum cpu temp allowed ..from bios...or find a way to install extra cooler fan...and reinstall for to be sure its all Ok...
Sep 04, 2009 | HP Compaq nc6400 (GJ982US) PC Notebook
IRQ nOT LESS OR EQUAL HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
irql not less or equal sounds like a graphics driver problem. All you needed to do was boot up in safe mode and remove the gfx driver and the OS would have rebooted with the default driver and then you could have reinstalled it
Oct 25, 2008 | Microsoft Xbox 360 Console
HP zt1170 freezing, blue-screen, IRQL errors, etc
First of all, I recommend you to try using the Notebook with the RAM you had purchased...and remove the preinstalled ones.
Try using the 512 MB of RAM you had purchased by inserting it into the other slot if you receive Bluescreens with the RAM installed in one slot.
If you receive the same Bluescreen errors again and again, the issue can be with a damaged Hard Drive which might be having some bad sectors.
Additionally, IRQL not less or equal error message you receive indicates that few of the Device Drivers you had installed are incompatible.
Check them if you are downloading and installing the required drivers from any third party website other than from HP.
Hope this helps...
Jul 27, 2008 | HP Pavilion zt1170 Notebook
Microsoft Xbox 360 Console Logo
130 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
