Question about Dewalt Drills
What opens dewalt drill to check motor - Dewalt Drills
  • 2,176 Answers
Depends on the drill model number. You can go to dewaltservicenet.com and with the model and type number you can download a parts diagram for the tool. Let me know if you need more help
Posted on Feb 21, 2012
My dewalt impact gun dcf885 when I press trigger the motor starts then dies
Mick, this could be a sign of a worn out/faulty motor, mine did this, ripped it apart and it was the motor. Yours may still be under 3 year warranty if you can find your receipt.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeWALT DCF885C2 Type 1 20V Impact Driver Parts
http://www.mmtoolparts.com/store/dewalt-impact-driver-parts
http://www.dewalt.com/en-us/legal/warranty/general-warranty-information
DEWALT ServiceNet
Jun 13, 2016 | Dewalt Drills
Drill dewalt not rotating smoothly backwords is to slow
u need to open it and chek if the both cables are ok...one of both have same kind of trouble and the elektrisity dont "flow" that afects the polarity of magnet of motor...and it does that..(sry for my english)
Sep 28, 2015 | Dewalt Drills
Dewalt Corded Drill won't turn on
TRY THIS TAKE THE DRILL REMOVE ALL SCREWS OPEN IT
FIND THE POSITIVE AND NEGETIVE ON THE MOTOR HAVE A 12 VOLT BATTERY AND 2 CABLES 1 RED 1 BLACK 6 F-LONG 1-CONECT THE POSITIVE CABLE TO POSITIVE ON BATTERY AND NEGETIVE TO NEGETIVE ON BATTERY NOW YOU CHECK THE MOTOR ON DRILL BY TAKING POSITIVE AND CONNECT TO POSITIVE ON DRILL AND NEGETIVE TO NEGETIVE ON DRILL IF THE MOTOR RUNS THE PROBLEM SHOULD BE SWITCH.YOU CAN BYPASS THE SWITCH SOLDER THE WIRES TO THE MOTOR AND USE IT IN THE MEANTIME. SCREW THE CASING BACK TOGRTHER
YOUR DONE VERY SIMPLE..
GOOD LUCK.
Feb 04, 2018 | Dewalt Air Tools & Compressors
What opens up dewalt drill to change brushes
usually there is a cover on the back with torx drive screws that need to be removed. Some of the motors do not have changeable brushes though. I would recommend going to dewaltservicenet.com and downloading a parts diagram so you can see if they are available and the cover that I mentioned.
Feb 20, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
My dewalt cordless drill stopped working in the middle of drilling a hole. is the trigger faulty/broken?
First before you open the tool ground yourself. The switch is probably static sensitive. Now open the tool and check for wires that may have come loose from the switch, or motor brush area. If no bad wires make sure the switch terminals are ok (not broken or bent and are tight enough to make contact with the batery terminals). Next check the brushes and make sure they move freely in the brush holders. You didn't state the model so it may not have brushes you can access. If all that is good disconnect the motor from the switch and secure the motor in a vise. Take wires with alligator clips and connect the battery directly to the motor for just a second to see if it runs. If the motor runs you have a bad switch assuming your battery is charged.
Dec 08, 2011 | Dewalt 18 Volt Compact Drill Kit
I bought new batteries for ,my dewalt dw958 drill and when I put the battery in, the drill ran for about 45 seconds then started to smoke and the drill died. The batteries are dewalt 18v xrp batteris
I am thinking the switch or motor is bad, check the switch first. you can locate parts at dewaltservicenet.com. Make a wiring diagram before removing anything, these parts are polarity sensitive.
Oct 28, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt cordless drill dc988- drill motor works intermitantly when trigger is pulled. Works a little better as it warms up. Im thinking vsr switch, brushes, or motor/armature. please help...
Test the brushes by catching it in a stalled condition when you have it triggered, then rotate it slightly. If it takes off suspect the brushes or a dead segment on the comutator.
If it doesn't respond to this, then consider the VSR trigger... open it and test by bypassing it when in stalled condition...
Mar 20, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
I have an 18 volt 1/2" drive cordless impact wrench made by DeWalt and when I pull the trigger the motor runs but not the anvil?
Sounds like you have a gear broke that runs from the motor to the shaft. Take it apart and check it out. easy to put back together. atleast you will know for sure and may fix it while it's opened up.
Jan 18, 2010 | Dewalt DW056 18 Volt Cordless Impact...
14.4v dewalt xr2 drill
Some cordless Dewalt drills do not have open motors allowing access to the brushes. However there are a few styles that do.
If you want to check, open your drill. Remove the screws from the housing. Then remove half of the housing. You can see the motor at the back of the tool. If there are vents at the back of the motor you may be able to see the brushes the removable type are connected to a gray or tan piece of plastic mounted at the back of the motor.
If the brushes are from a removable style you can purchase a brush set. If they are hidden in the motor. You will have to change the whole motor.
You can check the Dewalt Service Net web site to find out.
Apr 20, 2009 | Dewalt 18 Volt Compact Drill Kit
When i use the drill it smokes real bad where the batt. connects
you have a short in your drill motor. I would not recommend using it as it is possible for the battery to explode.
DeWalt is probably the best made drill motor. I would look to sending it back to the factory for repairs. Run the internet for DeWalt and get a phone # to call them. You never know, this may be a problem the factory may fix for free.
Nov 21, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
