Question about NEC MultiSync MT830 Multimedia Projector
MT830 Color Convergence (Blue Left - Yellow Right)
MT830 suddenly developed vertical color alignment issues. Yellow is trimming everything on their right edge and Blue is trimming everything on the left edge. This is only affecting the vertical edging of objects. The horizontal edges of objects appear to be fine. convergence I think it is acutally the Blue that is off to the Left. I have been through the alignments for vertical with no change. I am able to turn brightness and contrast down to minimize the distinction of the yellow and blue edges, but you can still see them. Thanks for helping!
  • 3 more comments
  • Anonymous Jan 26, 2008
    Did anyone get anywhere with a fix to adjusting color convergence?
    I have an NEC MT1030+ that has a magenta shadow to the left and above objects in the picture. I cannot figure out how to get into the menu that has convergence in it?
    I have seen posts on "AVS Forum.com" that talk about NEC projects having a 4digit code to enter after pushing the 'adjust' button. I have neither that button, or numerals to push for a code.
    Any help is appreciated.
    thx
  • sweli Jan 26, 2008
    Does anyone know how to get into the convergence menu's on an NEC MT1030+ ??
    I have a magenta shadow to the left and above objects in the image.
    I have seen posts on AVSforum.com that suggest pressing the 'adjust' button and a four digit code. I have neither on my remove or projector.
    Any help is appreciated!
    thx
  • roye Feb 06, 2008
    Hi, I have a similar problem with my LT 158 but the other way around - yellow to the left and blue to the right. Did you manage to get your problem sorted? If so I'd like to hear how to do it if possible.
    Thanks
    Roye
  • fahad kaleem Jun 12, 2008
    hi i have a problem that wen i replace the lcds of the prjectors MT1050 and MT1040 from the brand known as Nec i dunn get the perfect result my profession is to do so but i dunn get the required and satisfying result is there a software or a method of doin this act perfectly ??
    thanks in anticipation
    plz  if any one of the visitors reads this and noes the solution to this reply me on this email adress
    thedudefahad@gmail.com
  • ausivic Aug 01, 2008
    Where are the adjustments on the main video board of the projector for alignment of the three LCD screens,
    Thanks
    Victor
Sometimes a bad cable can produce a delay in signal, if shift is only in horizontal, check cable grounds. Of course, also can be an optical problem, but first check that. And check if the problem occurs with menues (they dont pass througt external cable)
Posted on Apr 09, 2008
I have mitsubishi projector,Model **-LVPS50U. The problem is that lcd panel (R G B) convergance mismatch, So,kindly help me how can i adjust convergance of RGB? I am wating for your reply.
Dhruba Bagchi
dhrubabagchi01@gmail.com
Posted on Mar 09, 2008
  • 3 Answers
Time for a new projector, of course i could sugest a few diferent projectors but i think i will only suggest one since i dont know what your projectors main application is. in my poinion the pk20 LED projector by mitsubishi is a very nice inexpensive projector with a lamp life of over 20,000 hours and costing about the same price as one lamp replacement for most dlp projectors the mitsubishi pk20 LCD projector will last for a very long time and by then there will be a better model available and posibly be less expensive, i have found these projectors advertised from anywhere between $300USD and $700USD at regular retail price but i bet you can get one for less on eBay. GOOD LUCK and BEST WISHES!
Posted on Nov 29, 2007
    Novelist:
    Champion:
  • 277 Answers
Take a look here: http://www.extremetech.com/article2/0,1697,1049289,00.asp "... The others, however, have lost portions or all of their blue channels. TI's theory is that the shorter wavelength and higher energy of the blue light apparently causes the organic polarizing material in the LCD to get lightburn much faster. TI showed us a damaged LCD panel that controlled blue light transmission, and there was a large spot in the center that was apparently burned out..."
Posted on Oct 31, 2006
My Viewsonic PJ860 projector (aka Hitachi CP-S860W) has developed a condition in which there is a yellow vertical stripe down the right edge of the screen and a blue vertical stripe down the left side of...
It does sound like this is an alignment problem of the blue LCD or a problem on the main board controlling it. I am not sure if this is a field adjustable unit. A call to the authorized service center should provide that answer.
Aug 11, 2010 | Hitachi CP860960LAMP Projector Lamp for...
Tip
How to Format an HP Recovery Drive
How to Format an HP Recovery DriveThe HP Recovery Drive is a partition HP puts on its hard drives for use in case the primary partition becomes corrupt or unusable. The recovery partition contains system files and the ability to boot and repair, format and reinstall the operating system if needed. For those who prefer recovery disks or who don't feel the need for the insurance of the HP Recovery drive, it can be formatted by following the steps below.
Instructions1 Open Disk Management by Right Clicking "My Computer" and selecting "Manage."
2 Click on "Storage" and "Disk Management."
3 Find the Recovery Drive partition. There are usually two partitions: the "C: partition" and the "HP_RECOVERY D: partition."
4 Right-click on "HP_RECOVERY D:" and select "Format."
5 Choose the File system and Allocation Unit Size and click "OK." The HP Recovery Drive partition will format and be available for your specified use
Tips & Warnings
Be very careful to not format the C: drive by accident.
on Dec 15, 2011 | HP Computers & Internet
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Mitsubishi WS-65869 65" blue color problem
Yes, you need to replace the convergence output amplifier IC's. They can be ordered on line. After removing the back you must remove the circuit board which houses the amps. Then desolder them and install the replacemnts. If you are extremely lucky there won't be any re-alignment issues with the new amps. Then you should be good to go.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blue and yellow color
Blue should converge on top of "yellow".Bad connection(s)
on blue convergence IC.Replace both IC's for durable repair.
Check pico fuses.Reset convergence alignment.
Oct 17, 2007 | Samsung HCL552W 55" Rear Projection...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Yellow vertical bar on right edge of screen
Your set is starting to get a convergence problem and the only way to repair it is by changing the convergence IC's,(3)one for each color,the blue migh be showing more now but soon all 3 colors will be out of alignment and you will not be able to correct it with the custumer controls,is great that it has worked for so long without this problem,if you are familiar with tv service you have a place to check but if you are not too familiar be safe and call for help from a pro-servicer.Let Us know how it goes.
Oct 20, 2006 | Sony KP-53V45 53" Rear Projection...
NEC MultiSync MT830 Multimedia Projector Logo
1,242 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
