Question about Janome Sewing Machines
How to replace fuse - Janome Sewing Machines
  • spriggs6
    spriggs6 Feb 20, 2012
    I'd like to replace the fuse in a Memory Craft 8000. Looking for details on how to replace it. I know it is not supposed to be user replaceable.
  • spriggs6
    spriggs6 Feb 22, 2012
    It was serviced 9 months ago and the fuse was replaced. We took the base off the machine and found the black box with 2 fuses. Unfortunately, neither fuse is blown. There is no power to the machine at all. Took the switch apart and it doesn't appear to be faulty. Anyone have any other ideas what could be wrong? I know curcuit board could be shot but isnt that why the fuses are there? It was working normally until the needle got stuck and only worked for a second after I got it unstuck. I know it sounds like it overheated which is why I thought it would be the fuse again.
  • Janome Master
  • 7,365 Answers
Check with sewvacdoctor.com
Posted on Feb 21, 2012
  • spriggs6
    Am I missing something? This website doesn't have anything on Memory Crafts.
  • even thou the switch doesn't appear to have any problem, it still could have went out
    some part of the computer parts could have went out
    when the sewing machine jammed after the needle got stuck could have triggered a safety device in the machine that locked it up,, only a sewing machine repair shop can tell you excatly what wrong
How to replace the fuse on a 1020 bernina
The fuse is probably on a circuit board. The first problem would be getting the cover off the machine to access the circuit board. Then figuring out which fuse it is and what is involved in replacing it (could be soldered).
IMHO, it may be better to take it to a professional.
Jun 06, 2016 | Bernina Sewing Machines
I found a fuse F4 250V. T1.6A blown. After replace it and turn on the power, my control panel, PSC box and motor doesn't have any power.
Mostly a fuse doesn't fail without a good reason. Sometimes the fault is intermittent and replacing the fuse makes the machine or device work again for a long or short time though it is almost a forlorn hope.
Best practice is to thoroughly check and discover the cause of a failed fuse before replacing it a second time (there usually is a second time).
In your case the reason the fuse failed was probably something else failing in a quite permanent way rather than an intermittent way. It is a nuisance but at least a permanent fault is easier to find than an intermittent one.
The wiring and internal circuitry will need systematic checking both visually and electrically.
Mar 28, 2016 | Sewing Machines
Replace fuse
Because of the noise it sounds like a motor problem! The fuse is in the mains plug and is easily replaced!
Nov 09, 2014 | Brother LS-2125 Mechanical Sewing Machine
How to replace fuse on janome 4623 limited edition plus
The link to the user manual for this unit is below:
Janome 4623 LE User Manual
It might not actually be a fuse. Please review the manual, especially the troubleshooting tips on pages 48-49.
Nov 10, 2013 | Janome Sewing Machines
My machine shows an error number E1what is it
The error code 1 indicates the fuse on the A board has blown. The fuse should be replaced with a part number 000182177 fuse. The original fuse is a 2.5 amp fuse and the replacement fuse is 3.15 amps.
You should take the sewing machine to a Sears service center or a retail store for repair.
Sep 11, 2012 | Kenmore Sewing Machines
Is there a replacement fuse or power supply for Husqvarna Viking 990??
check with husqvarna customer service about the fuse or power supply
Feb 27, 2012 | Husqvarna Sewing Machines
My Husqvarna Rose is dead. My husband tried to replace the bulb and it was the wrong one and it wont turn on at all. IS this too a fuse. Where is the fuse on these machines
You can check inside the power supply unit for a fuse, but I think he probably blew a voltage regulator and the power supply will need to be replaced. Contact an authorized Husqvarna Viking repair center.
Dec 13, 2010 | Husqvarna Viking 1
Need fuses for janome 4000
You can get the fuse at Radio Shack. Part number 270-1065. It is a 3.15 amp 250 volt slow-blow fuse.
If you replace the fuse and it blows again, you need a new A circuit board part number 829606005.
Nov 03, 2010 | Janome Memory Craft 4000 Sewing Machine
My Janome 9000 also quit a few months ago, took it to repair shop and they replaced a fuse. Have only used it about 2hrs since and it did the same thing again. So we decided to replace fuse...
Your fuse is blowing because there is a bind in the machine. Did they service the machine when they replaced the fuse? If yes, it should be under warranty. Best guess is that it is tight from lack of lubrication, usually at the bushing nearest the hand wheel.
sewman7
May 13, 2009 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
26 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
