Question about Dewalt 18 Volt Compact Drill Kit
What epens drill to get to motor
Is it a allon key or something else
Use a10mm torque driver
Posted on May 30, 2012
I would like to know the size of chuck key needed for this drill
Can't answer the question; you did't mention the brand name or model number of the drill...however, take the drill motor with you to your local hardware store...they should be able to match a key up to your drill
Mar 23, 2015 | Drills
Why does my drill chuck seem to disconnect from the motor?
from pos 32 gear and the drive shaft on the armature can be worm out. or something was broken else.
Detail
Jul 23, 2014 | Dewalt DW505K 1/2" Hammer Drill
Change head gasket on 2006 grand marquis
Leave the motor mounts allone, they are fine where they are. Your torque sequence usualy start at the center of your head and working a circle outwards usualy.
Mar 03, 2013 | 2006 Mercury Grand Marquis
How do you switch off the epen mouse? I lost the instruction manual and cannot find a way to switch it off (and on) manually. The blue laser is keep on and I don't want to waste it.
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 06, 2011 | Ezonics ePen Mouse
Chuck is stuck open cant get to free how do i replace chuck
You need to secure the drill - perhaps in a vise - and insert the chuck key (if it is a key-less chuck you may have to use a pipe wrench or something similiar) and give the key (or wrench) a sharp hit to release it. The chucks are screwed onto the drill with a right hand thread. Let me know if this works for you. Thanks
Jan 02, 2011 | Milwaukee 0200 20 Drill 3/8 1200 Magnum
Need to change chuck
When you buy a replacement chuck it will have detailed instructions- at least Jacob's brand chucks do. Basically there is a retaining screw inside the chuck that needs to come out first- it may be left-hand threads . Then you put the short end of a 1/4" or larger allen wrench in the chuck and close it tightly. Set the drill on a bench with the chuck off of the bench and strike the allen wrench with a mallet in a counterclockwise direction. Do this several times, then you'll be able to spin the chuck off by hand. Reverse the process to install the new chuck.
Apr 13, 2010 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
How do you remove belt tensioner on a 1999 escort zx2 4 cylinder
There is a screw right in the middle of the tensioner..It may be a Hex, or Allon Key, but double check it, before you stick the wrong tool inside, and strip it...Goodluck
Dec 04, 2009 | 1999 Ford Escort
Drill heats up immediately that without gloves on you can't hang on to it.
have the johnson drive motor changed - something's wrong with the motor
Oct 20, 2009 | Dewalt 18 Volt Compact Drill Kit
Makita 2071 Smoking, probably overheated but still working
When an AC motor is stalled, very high currents pass through the motor windings and melt the insulation on the windings; the smoke was the result of the motor winding insulation being melted. This causes a reduction in motor torque and premature failure.
You should suggest that your neighbor buy you a new drill and he keep the one that he ruined.
Aug 31, 2009 | Makita Drills
Driver epen for vista
Put windows xp on your computer there is much better driver support and a lot less repair related issues. And as far as I could tell they do not have a vista driver. I would suggest calling the manufacture Monday and asking there tech deparment to see if they have it hidden somewere.
Mar 22, 2009 | Computers & Internet
Dewalt 18 Volt Compact Drill Kit Logo
22 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
