Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Tumble dryer has stopped working
It doesn't seem to heat up when on a drying cycle. I found suit on the back panel when I removed it to unblock the filter
  • Philip Tinsley Feb 22, 2012
    there was also a leak from the front powder drawer, when I unblocked the filter it has stopped leaking - but it still won't dry. Would the 2 problems be linked.....
  • Philip Tinsley Feb 23, 2012
    Cause the washing m/c works ok i would assume the pump is working to pump the water from the washing cycles.
You can check pump ,if pump isn't working water stay all time .
Posted on Feb 22, 2012
4 Suggested Answers
Malcg
  • 32 Answers
SOURCE: tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Posted on Apr 13, 2008
barkencoa
  • 3463 Answers
SOURCE: WD62 hotpoint washer dryer
You will find the filter located inside the large black hose attached to the bottom of the drum.
Remove the securing clip, and detach hose, you will see the plastic filter inside the hose.
Remove and clean.
Be careful when you remove hose, as there will be some water in it.
Fit back in reverse order, and make sure the hose is on properly.
Plz rate my solution.Thanks.
Posted on Dec 24, 2008
barkencoa
  • 3463 Answers
SOURCE: Hot point wd64 dryer
U need to check the heater element and/or the stats on the top of the heater box located on the top of the drum for continuity, with a meter.
Disconnect from the supply, and remove wires from components to check for continuity.
Hope this helps u.
Plz rate this solution.
Thanks.
Posted on Dec 31, 2008
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 | Dryers
I get a AF code and the blower is not turning. Dryer is turning and heating.
Sounds like you need a new blower wheel. You would need to remove the drum and front panel.I think it is a reverse thread on blower wheel.
Feb 23, 2018 | Whirlpool WED7600XW Dryer
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
Whirlpool ggw9868kq .Ducts are clean, airflow is good. Drum rotates. Dryer warms up then heating stops. happens in both auto and timed cycles.
My whirlpool dryer Model GGW9896KQ2 seems to run ok but it doesn't seem to heat up properly and takes several cycles to dry clothes. I checked the exhaust vent and it seems to be blowing air out ok. Also, it appears the dryer goes to the cool down cycle way to early. In addition, the dryer will sometimes shut off before the time is acutally done. help--I don't want to spend money for a tech or even a new dryer. It's only 8 years old.
Aug 06, 2011 | Whirlpool GGW9868K Gas Dryer
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
No tumble action, belt seems fine
the belt has to be replaced
May 12, 2009 | Dryers
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
85 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
