Question about Husqvarna Sewing Machines
I have a designer 1 viking HUS sewing machine Last night I jammed a needle and something happen to the bobbin winder. The round thing on the side(???) won't work(so the needle willn't go upa
When the neddle jammed there was a loud jamming sound. Something is jammed with the bobbin winder
  • Husqvarna Master
  • 7,365 Answers
It's possible that when the needle jammed it put the machine out of time
it needs to be checked at a sewing machine shop
Posted on Feb 21, 2012
Zenqi
  • 208 Answers
SOURCE: Viking Husqvarna #1 + - A bobbin was stuck on the
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Posted on Jul 11, 2009
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Posted on Mar 25, 2008
bargainbox
  • 1388 Answers
SOURCE: neddle not picking up bobbin thread
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
  • 980 Answers
SOURCE: I have a Viking Husqvarna and it seems that the
If the winder is not moving either there is a worn part on the winder rubber, or, the winder iteself may have seized up becuae a lot of people do not realise that the spindle has to be oiled because of its high speed.
Posted on Nov 05, 2009
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
My needle still goes up and down when I put the machine in the bobbin wind position.
There are two possibilities here; 1 you may not have the bobbin all the way down on the holder, 2 you may not have really engaged the bobbin winder. I would take the bobbin off, return the machine to sewing position, turn it off. Then turn it on, replace bobbin in position and re-engage the winder firmly! Good luck.
Jan 18, 2015 | Husqvarna Viking Emerald 116 Sewing...
How to fix viking designer 1 broken bobbin winder
If you mean the bobbin winder mechanism where the bobbin slips on to the spindle is loose, the pin that holds it in place has come out. It's an easy fix but requires that all the covers be removed. Suggest taking it to an authorized Viking dealer for repair. You can find your local dealer by going to the Viking website - http://www.husqvarnaviking.com/us and click on Locate a Dealer.
Jun 09, 2014 | Husqvarna Viking 1
Bobbin thread coming into design
try lowering the upper tension. you may need to have your authorized Viking dealer rebalance your tensions.
Apr 11, 2014 | Husqvarna Sewing Machines
The bobbin on my Husqvarna sewing machine (Viking 100) is stuck on the bobbon winder
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
Oct 14, 2010 | Husqvarna Viking 1
Needle not working but bobbin winder going round
there is a clutch you disengage it to wind the bobbin and you engage it to sew. instruction book?
Feb 25, 2010 | Husqvarna Viking 1
I have a Viking Husqvarna and it seems that the bobbin winder won't disengage. when you press the pedal down the needle doesn't move but you can hear the bobbin spinning but when you put a bobbin on the...
Nov 05, 2009 | Husqvarna Viking 1
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Husquarvana Viking model 630 needle doesn't move when powered up
if the balance wheel is moving round okay manualy it could be but it could be thread lock or just a tiny bit of fabric stuck in the workings
Jun 12, 2009 | Husqvarna Viking 1
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
171 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
