You probably already figured this out, however, more then likely it is the circuit board. It cost aprox $91 (taxes not included) its relativly simple to replace. I had the same issue and that did it for me. Make sure you mark all your connections before removing them and maybe even take a few pictures in case. Good luck!
There is a Primary High Limit Switch towards the middle of the furnace, it more than likely needs to be replaced, very common to go out only after a few seasons. Also, you could have a flam rollout switch tripped that will signal the same code, these switches are re-settable and are located on the outer top and sides of the burner assembly, they’re about ½ inch in diameter with a red push button in the center and two wires “ usually purple” coming off of them. If either of these are tripped or bad, the blower will stay on indefinitely.
Hope this helps
Does your hot surface ignitor glow upon start up.
