SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: universal remote codes
I found the following web site which lists the codes for the RCA SystemLink 4 RCU400C universal remote. It's http://www.thompsontv.com/rcarc.html.
SOURCE: MD 80383 user manual
Follow the instructions in the manual, just quickly press and release the buttons, except the S button of course.
So the last 3 buttons pressed are the Learn button, the button on the universal control you want to assign the particular function to (let's say Program +), let go of all the buttons and press (in this case) Program + on the original control, and keep on pressing until the steady lighting on the Source Key starts diminishing. Then let the Program + key go, turn the Universal Control over and temporarily dislodge a battery. The function should now be transferred to the universal remote. And make sure the eyes of both remotes are as close together as you can manage.
SOURCE: need manual for newstar universal remote control model 96-1014
Need manual for newstar universal remote control model 96-1014
* For text ads, append each ad to the string.
for(i = 0; i ' +
'Ads by Google' +
google_ads[i].line1 + '';
url = '' +
google_ads[i].visible_url + '';
info = makeBoldAdWords(google_ads[i].line2) + ' ' +
makeBoldAdWords(google_ads[i].line3) + '
s += url + info;
s += '';
s += '';
document.write(s);
G_GGL_SKIP += google_ads.length;
return;
var G_MAX_ADS_WL = 1;
google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#)
google_ad_channel = "2438490332+4447185069+1147946396";
google_ad_output = 'js';
google_max_num_ads = '1';
google_ad_type = 'text';
google_feedback = 'on';
if(typeof G_GGL_SKIP == 'undefined')
G_GGL_SKIP = 0;
google_skip = G_GGL_SKIP;
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
SOURCE: I have a technika 4 in 1 universal remote tr41r
I can supply codes but since there are thousands of codes in your question add the make of each of your controlled components...TV, DVD, VCR etc (just the company) and I will give you the codes that I have.
