Question about Air Tools & Compressors
Craftsman compressor motor/capacitor problem?
I have a 33gal craftman compressor mod.# 919.167340, it trips the breaker on startup, even under no load conditions. The motor turns freely. I'm not sure how to check the motor start capacitor to see if it is good. I have heard on a slightly older model a problem with the centifugal switch, but this one seems ok (looks like a newer design). The capacitor itself doesnt look or smell burnt, I know they are cheap but I can't find a replacement. Also the capacitor has a resistor soldered between the 2 posts of the capacitor. Any help would be greatly appreciated.
Thanks
  • mosenga1 Nov 11, 2008
    Same problem - trips the breaker when turned on.
I had the same tripped breaker problem with a similar Sears model 919.195060 (25 gal) and luckily I had access to another, almost identical sears compressor to swap parts to diagnosis it. It turned out to be the run capacitor, but from what I was finding in my on-line research, it could have been a bad winding on the motor or the start capacitor just as easily. If your resistor is outside of the capacitor, just cut the wire right at the capacitor and add flag termnals Mine had 3 wires coming out of the capacitor (not the normal terminal cap style), and two of them were basically just tied together (same color). I didn't have an external resistor. I bought a GE 97F9614 run capacitor (40 mf, 370vac) and other than having to cut out a bit of the plastic on the mounting bracket and buying "flag" style 1/4" terinals from radioshack, it fit and worked perfectly. It seems if GE is the only one that has the right dimensions (1.75dia x 3.88 long, not including the terminals. That capacitor cost $27.50 with tax at a local electric motor shop. Sears doesn't even have any info on the motor parts, like capacitor - they want to sell you a new motor for almost as much as a new whole compressor. I ended up looking at parts forr the motor on a Devilbliss (that's what the 919 means on the model number, that it's made by Devilbliss), but it was not an easy way to go and really didn't help that much). The easier/normal way of matching capacitors is to measure the case dimensions carefully and match up the voltage and uf (or mf) specs,
Posted on Dec 22, 2008
  • 3 Answers
I also just came into possession of this compressor with the same problem. Tripped the breaker when turned on. All I needed was a run capacitor. Here is a link to the right one for this motor.
http://www.alliedelec.com/search/productdetail.aspx?sku=70102977&gclid=CMSYgPqHmbYCFQ6ynQodyEoA7w
I found a suitable replacement at a local AC repair place for a few bucks more. Doesn't have to be exact, just the same spec.
Posted on Mar 25, 2013
I have a 220 air compressor and I need to know with wire is with so I can put another plug on the end.There is 3 colors of wires and I dont know whay wires are ground and hot
Posted on Oct 29, 2008
3 Suggested Answers
  • 121 Answers
SOURCE: craftsman compressor motor/capactitor problem?
It sounds like you have a shorted motor. Through your motor leads you can ohm it out to check for open winding or you can take the motor to an electric motor shop to have it checked. The capacitor can be checked by an ohm meter, by touching the two poles you will see the meter spike and then fall back to 0. Each time you test it you will need to switch the leads to opposite poles. Again a motor shop can check this for you usually for free.
Posted on Oct 27, 2008
It sounds like either the check valve or the switch that lets the air pressure off of the pressure switch is broke. After the compressor pumps to shut off pressure, when it shuts off, it should let a short burst of air from the switch. If it does this, that parts good. Give it a little time, then manually push that plunger on the switch.( you're trying to see if the check valve, which is a one way valve, is leaking air back into the cylinder) If air is release from that plunger, the check valve is leaking and will not let the compressor start, because air has leaked back into the cylinder.
Posted on Mar 11, 2009
Compressor trips breaker on startup or quickly after
The breaker may be too small. Check the amperage requirements against the breaker size.
May 31, 2012 | Craftsman 33 Gallon Vertical Portable Air...
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
I have a Sears 33gal vertical compressor. About 8 years old. I keep tripping circuit breakers whenever the compressor is activated and starts to pump. Please advise
either the motor is bad or the pressure relief valve is inoperative forcing the compressor motor to try to start with pressure already in the pump
Oct 15, 2010 | Craftsman Air Tools & Compressors
Compressor won't sstay running and trip breaker
You gave a lot of information, but you didn't say if it worked when free wheeling. If not, I would suspect the inertia switch. If it is working, you should hear it click when the motor is winding down after being shut off, at least when free wheeling. A 20 amp breaker will certainly handle a 15 FLA motor, even on startup. They don't trip at 20 amps exactly, especially on a simple overload. Even at twice the rated amperage, it can take several minutes to trip it. They will trip quickly on a dead short, however, or a severe overload. I doubt the windings are shorted or it either wouldn't work (start windings) or would run at a slower speed with the inertia switch constantly tripping in and out with it coasting while tripped in (i.e., accelerate, coast, accelerate, coast, etc.)
Mar 06, 2010 | Dewalt 2 Hp 4 GAL Air Compressor
My 33 gallon air compressor will at start build up to 120 psi and shut off, after use and at about 80 psi the motor tries to start but kicks our circuit breaker? Any help would be greatly appreciated!
Most likely it is the unloader valve. This is inline with the air filltube from compressor to tank. Somestimes the unloader valve is screwed into the tank and air tube is attached to it. This device takes the pressure out of the tube so the compressor can start without the back pressure from in the tank. Other possibility, the start capacitors of the motor. The capacitors must give a kickstart upon startup or the motor will just hum for a couple seconds and overload the breaker. A tempoary solution is to turn off the power to compressor when it reaches 120psi, then allow the pressure to drop to 40 or less, then turn power on and mostlikey compressor will start with a load of 40psi or less. It is a nuisance but it works until you replace the bad part. Goodluck,Macgivor
Jan 16, 2010 | Craftsman Air Tools & Compressors
Compressor won't restart with any pressure in tank
try replacing the capacitor. a bad start capacitor will not let it start under a load.
Jul 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman Compressor runs Intermittantly
I have repaired many craftsman compessors with the problem that you are having. I just use the process of elimination to find the broken wire. I use a short pigtail and attach it to the motor side of the pressure switch. This will isolate the motor from the switch and the power cord. Use caution not to overfill the compressor as this will test the safety valve. If the motor runs ok then move the pigtail to the powercord side of the switch. This will eliminate the power cord. If problem is within the motor check the connectors under plate and capacitor cover. To test the capacitor you will need to find a meter with cap test capabilities or repair shop will test for free. The cap should test within 95% or printed value in (uf). If all parts test ok then motor could have internal thermal breaker that is weak. Good luck.
Jan 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Starting problems
IF YOUR PRETTY SURE DRAW A CAPACITOR WIRING DIAGRAM AND THEN TAKE YOUR CAPACITORS TO ANY MOTOR SHOP OR SUPPLY HOUSE LIKE WW GRAINGER. THEY CAN CHECK THE MICROFARRADS OR UNIFARRADS OF YOUR CAPACITORS. YOUR START CAPACITORS HAVE THE LARGER MF OR UF RATING AND ARE TYPICALLY LARGER IN SIZE. YOUR P.O.S. INGERSOL RAND MAY EVEN BE A 3500 RPM MOTOR AND COULD HAVE UP TO 5 CAPACITORS. 3 OF WHICH ARE START. IS YOUR WIRE LARGE ENOUGH? IS YOUR BREAKER LARGE ENOUGH? IS YOUR COMPRESSOR UNLOADING THE HEAD PRESSURE WHEN IT CUTS OFF? IS IT OUTSIDE AND TOO COLD IN THE MORNINGS? MAKE SURE YOUR WIRING IS LARGE ENOUGH BECAUSE THAT IS USUALLY THE PROBLEM. YOU HAVE SINGLE PHASE BUT IS YOUR VOLTAGE CORRECT 208V OR 230 V. ALL WIRING AND GAUGING CHARTS ARE BASED ON 100 FT OF WIRE . MOST COMPRESSORS PULL 3 TIMES THE AMP RATING ON INITIAL STARTUP THEN COM DOWN TO AMPS LISTED ON THE MOTOR.
Jan 16, 2009 | Ingersoll Rand - Rand Type - 30...
Craftsman compressor motor/capactitor problem?
Oct 27, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
5,248 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
james allen
james allen
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
