Question about Dakota Dodge RB4 Navigation, CD, AM/FM, with CD Changer Controls
I have a Navigation dvd stuck in my cadillac sts Navigation unit, how can I get it out?
I have a 2006 Cadillac STS and I wanted to replace the old 2006 DVD Map disc with a newer DVD, but when I try to eject the old Map DVD it will not eject.
3 Suggested Answers
SOURCE: How do you remove DVD stuck in navigation system
If you remove the unit from the dash the top, take off the top cover, no screws you can acess the CD slot. Remove the 4 screws holding the CD player in place and the ribbon cable and you should be able to remove the CD from the slot.
Posted on Jan 09, 2008
mlake33
  • 427 Answers
SOURCE: DVD Stuck
Try to look in the dvd player's instruction booklet for an ejection hole. Ususally dvd players have a hole where u stick a paper clip into it and it ejects the dvd. If not, contact the vehicle's dealership for assistance.
Posted on Mar 24, 2008
Location of map sensor on a cadillac sts 2005
Which engine ? 3.6 or 4.6 ?
One of them doesn't have a MAP sensor !
Manifold Absolute Pressure (MAP) Sensor (w/LH2)
Front center of the engine in the back of the throttle body
Engine Controls Component Views in Engine Controls - 4.6L
May 22, 2017 | 2005 Cadillac STS
Does it have a ignition relay switch?
Nicole, I google it and the 06 Cadillac STS does appear to have a ignition relay. It will most likely be found in the engine compartment fuse/relay box. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.rockauto.com/en/catalog/cadillac,2006,sts,4.6l+v8,1432044,electrical-switch+&+relay,ignition+relay,3480
2006 Cadillac STS ignition relay Google Search
May 22, 2016 | 2006 Cadillac STS
99 cadillac deville flywheel replacement
1979 Cadillac Coupe 425 engine running; flywheel knocking
? 1:16
https://www.youtube.com/watch?v=UTDBmkKyBCY
Sep 30, 2011 - Uploaded by Edgar H
1979 Cadillac Coupe 425 engine running; flywheel knocking ...Change Transmission Fluid pan removal Cadillac Seville part1 - Duration: .
Exclamation Re: Found a 94 STS for $800, needs flywheel ...
www.cadillacforums.com/.../cadillac-seville-cadillac.../65815-found-94-s...
Feb 16, 2006 - 15 posts - ‎9 authors
Cadillac Seville / Cadillac Eldorado Forum Discussion, Found a 94 STS for $800, needs .... If it is somehow just the flywheel, your repair cost would be the labor involved in dropping ... Automobile(s): 1999 STS - diamond white. Re: flywheel 99 sts
Apr 7, 2013
Re: need to replace flywheel
Dec 3, 2011
Re: Location of transaxle to engine bolts on 1998 ...
Nov 13, 2011
Re: How to lock flywheel without $150 tool?
May 21, 2009
More results from www.cadillacforums.com
Jan 11, 2016 | Cadillac Cars & Trucks
Trunk fuse 2006 sts
The fuse is located under the rear seat in the fuse box.Trunk/valet fuse.
Feb 04, 2015 | 2006 Cadillac STS
2006 cts nav disc keep ejecting
If you can play a DVD, the nav disc is dirty or worn. Try gently cleaning it with a flat screen tv cleaning solution and try again. If a DVD won't play, the read head in the player is either dirty or shot - you should have an A/V shop try to clean it, as replacing the unit is $$$$$.
Sep 09, 2014 | 2006 Cadillac CTS
What does code po496 mean on my cadillac sts 3.6l
your evaporative emission canistor solenoid purge valve is either stuck open or shut and needs to be replaced-auto zone pep boys or advanced auto can hook up diagnostic and confirm for free-cheers Denny
Oct 11, 2013 | 2006 Cadillac STS
Where can the cigarette lighter fuse for the cadillac sts 2005
Im havung trouble finding the fuse box to change out my fuse for the cigarette liter
Mar 16, 2013 | 2005 Cadillac STS
2006 cadillac sts battery dead can't access car because uses a pod instead of key?
Most of the time, newer cars are going to be faster than older cars, unless they have been completely restored.-----------------------------------------------------------------------
FGTech Galletto 2
Dec 14, 2012 | 2006 Cadillac STS
2006 cadillac sts fuse box diagram
On this website you find information (diagram, description and location) about fuse boxes in Cadillac STS mk1 (First Generation; 2005 - 2006)
Cadillac STS mk1 First Generation 2005 2006 fuse box diagram Auto Genius
Jun 27, 2012 | 2006 Chevrolet Impala
Car Audio & Video Logo
218 people viewed this question
Top Dakota Car Audio & Video Experts
xxxxxx xxx
Are you a Dakota Car Audio and Video Expert? Answer questions, earn points and help others
