Question about Kenmore 74972 Gas Dryer
Lint screen I have someone telling me that her dryer dries at what she says is same as always but that she never gets lint on the screen. How can that be possible if it is drying normal?
    President:
  • 878 Answers
Ledhed, Been doing this for over 25 years and I haven't seen one yet that doesn't catch lint when operating normally., ...Catriver...post back.
Posted on Aug 26, 2006
Clothes get caught
Instructions
Remove the lint screen from the GE electric clothes dryer.
Roll the lint from the screen with your hand. If the lint screen is clogged with fabric softener, fill a sink with hot water and add 1 to 2 tsp. dish soap.
Scrub the lint screen with a soft-bristle brush and soapy water. Rinse the lint screen thoroughly and shake off any excess water. Set the lint screen aside to air dry while you clean the dryer exterior.
Dampen a cloth with warm water and wring it out. Wipe over the GE electric dryer exterior to remove any lint, dust or product residue. If the dryer is very dirty, dip the cloth in the soapy water and wipe away any spots.
5
Wipe the GE clothes dryer with a towel to dry. Replace the lint screen when it's completely dry.
Jan 09, 2013 | GE DCVH515EFWW Electric Dryer
Gew9868kq0 not drying
Hi it could be that one of your heater element coils blown or a faulty thermostat
May 28, 2012 | Whirlpool GEW9868K Electric Dryer
I have a wdr1242 washer dryer the dryer seems to take forever to dry clothes sometimes 2 hours or more even for just half a dozen socks
If your dryer is still heating up; Check the dryer vent hose, also check down inside where the lint screen goes. If no lint is obstructing there, check the exterior dryer vent. Sometimes you have a screen to keep birds and rodents out of there, and may become clogged with lint. If no screen, check inside the flap, maybe someone moved in, or dryer lint is clogging up your exterior vent.
Dec 08, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Nov 16, 2009 | Hotpoint Aquarius WD63 Front Load...
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer not drying
your dryer is likely clogged up with lint .. that would be after the lint filter .. the pipe that carries the hot air out is usually completely clogged after that long .. it and the dryer itself (down inside) has to be cleaned about once a year to keep it tip top .. hopefully you can find someone that can take it apart and clean everythiing .. that should get you back to like new performance .. or you could call a few handymen to see what they would charge to clean the lint from your dryer and stack .. or if you are handy there is a special big brush with a string attached .. you pull that thru the stack to clean it .. use a vacuum cleaner to get inside the dryer vent (you can see in the vent when you take the hose off .. excessive lint buildup not only greatly reduces your dryers efficiency but is a fire hazzard as well ..
Aug 12, 2009 | Whirlpool LER5636P Electric Dryer
Dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Jun 23, 2009 | LG DLE5955 Dryer
Dryer doesnt dry clothes
I suspect you have a blocked air vent. A blocked vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
Jun 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer screen
No. The accumulation of lint in the dryer screen generally doesn't have anything to do the amount that ends up INSIDE your dryer. Too little lint is not a bad sign. It's dependent upon the type of clothing you are drying as well. If the clothes are not "lint givers" (like cottons and wools), you generally won't see a lot of lint in the dryer screen. Dryer screens are not perfect, either and some lint always gets through. As long as there are no holes in the screen and you have it seated correctly, and you clean it after each use, you shouldn't have any problems.
What affects dryer performance the most, is your vent hose and routine cleaning. The simple rule of thumb is: The SHORTER and STRAIGHTER the vent hose the BETTER. The vent hose should also be cleaned thoroughly periodically. I recommend once per season. That's about 4 times per year. What causes the lint to back up into a dryer is when the vent hose becomes kinked or clogged. The lint is mixed with moist air when it leaves the dryer. If it has no where to go, it starts to accumulate and stick in areas of the vent hose that are sagging, or at tight bends. Eventually, the vent becomes so restricted that the lint ends up inside your dryer. This causes the heating circuits to overheat to eventual failure. Not to mention, accumulations of lint inside a dryer can cause a fire. I have personally inspected dryers that were so full of lint that the dryer hose contained about a gallon of water from condensation and the inside showed evidence of multiple fires. If you need further info, I have an article I wrote up explaining all of this under "Tips and Tricks" under my profile. I hope this helps you.
Apr 06, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 74972 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
