Question about Dishwashers
Whirlpool Quiet Plus Dishwasher
Well, I went to turn on the dishwasher tonight and none of the buttons on the panel were working. I cut the breaker on and off....still no luck. I made sure nothing was blocking the heating element or the washer blade. I noticed directions on the panel to press the Air Dry button for 5 seconds to lock/unclock the control buttons. I did this and that particular button showed a red light.....still no luck with the other control panel buttons. I pressed the Air Dry button again, thinking maybe I locked the control panel the first time and now was unlocking it. Still no luck.
Any ideas?
    Brigadier General:
  • 6,966 Answers
Hi again,
Lost you on the Live Session. Have you checked the bottom plate/panel? We need to determine the error code by entering the diagnostics cycle. How you enter it varies by model. the machine's tech sheets should be located on the dishwasher somewhere, usually on the back side of the bottom kickplate.
In some models, probable fault are:
  • door latch (likely);
  • heating system (most likely).
Incidentally, there was a recall order on some Whirpool models due to the heating system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 27, 2008
  • Dishwashers Master
  • 13,433 Answers
If your dishwasher doesn't work at all, check these:'
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Kenmore dishwasher wont turn on seems to have no power.
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Feb 13, 2012 | Kenmore Dishwashers
My whirlpool dishwasher quiet wash plus, does not respond at all. None of the buttons work. The last cycle I ran was fine, now, nothing. I've checked the breakers, no problem there. Is there a...
Hello, welcome to FixYa. Your post indicates your machine is a Whirlpool, however if you could post the actual model number I could speak specifically about your machine. Initially it sounds like a burnt wire in the junction box or a burnt hi-limit/fuse in the control panel...if applicable to your model, hemce the need for the number. I will watch for your reply. Good luck. Thank you for choosing FixYa. Regards, Macmarkus :)
Jul 06, 2011 | Dishwashers
Whirlpool dishwasher model DU920PFGB4 will not start.
my dishwasher is only 2years old and will not start. the lights on the panel come on but wont start.
Sep 26, 2009 | Dishwashers
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
Apr 21, 2008 | Dishwashers
Dishwashers Logo
132 people viewed this question
Top Dishwashers Experts
