Question about Philips GOGEAR SA6045 MP3 Player
Volume is stuck
I accidentally pushed the volume limit on my mp3 8 gb player, and it's a really low setting, Now I can't listen to it at work(I work in a loud area) and I have a hard time listening to it at home(I'm hearing impaired).
How do I get it unstuck. I'm afraid if I stick a pin in the reset spot, I'll delete all my music and my music is from several different home computers.
Any suggestion will help!
Thanks
  • 149 Answers
I would load all of the music onto one single computer, then reset it and then if it deletes all of your music you will have it backed up.
Posted on Oct 27, 2008
Remove lock from volume setting
Limit the volume Listening to loud sounds for longer than a moment can be harmful to the listener. You can set the volume level of the player to suit your preferences: 1 From the main menu, select Settings > Sound settings > Volume limit > Settings. 2 Press Vol- or Vol+ to adjust the level. 3 Press to set. > When you set a volume limit, you can no longer exceed the set volume, even if you press the Vol+ button. To enable maximum volume again, set the volume limit back to maximum or turn off, select Settings > Sound settings > Volume limit > Off.
Thanks for rating Good luck
Dec 22, 2010 | Philips Audio Players & Recorders
Very low volume on a brand new ipod touch what should i do to fix this problem
Turn on Ipod, on the left hand side there is a volume control switch. While you are on a song, hold the top of the volume control switch to increase the volume.
If that does not work then touch "settings", then touch "music" and make sure your "Volume Limit" is set to "Off", if it is not touch "Volume Limit" and set it to "Off".
Please do not forget to rate me
May 16, 2010 | Apple iPod touch Second Gen (8 GB,...
I don,t remember the combo for the lock I put on my volume limit.How do i restore volume? I locked it accidentally on low .
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
Then go to Settings and then volume limit and change it to your required volume
Nov 04, 2009 | Apple iPod nano 2nd Generation MP3 Player
Volume stays low won't increase
Your volume limit on your ipod is probably set low. To check it, go all of the way to the ipod's main menu and go to settings. Then go to volume limit and put it where you would like it to be if it is too low. Then go back to your music and play it. Turn the volume up to your liking and it should work and play louder.
Apr 06, 2009 | Apple iPod MA446LL/A MP3 Player
Volume button stuck
i think you cotinously keep on increasing and loweing the volume in you sandick mp3 player
take it to the repair electronic shop
the rubber below your volume key get dispalced sometime or get stuck due to which it doesnt work.
dont worry i hope it can be repaired
Dec 11, 2008 | SanDisk Sansa Clip MP3 Player
Volume limiter on ipod
Go to the main screen, scroll to settings, scroll to volume limit, scroll it all the way up. Then either hit the play button and enter a 4 digit code to save it, or hit menu to return to the previous screen and it should save on its own.
Sep 01, 2008 | Apple iPod MP3 Player
Volume code
As far as I know, there is no unlock for the volume. If you go into settings there is a volume limit. If you go to it just scroll up to the maximum and press the center button. That's maximum volume set. Then play a song and scroll the volume all the way up. If you're still not getting any sound then your headphone cable might be broken. Try the iPod on some sort of docking bay that produces sound. If it works on there then you definitely have a faulty headphone/hold cable. If it doesn't work on the docking bay, then you have a faulty logic board.
Jul 26, 2008 | Apple iPod MA446LL/A MP3 Player
Low voice of ipod shuffle
it is probably low on voice because u have to go 2 settings ,volume limit then put in all the way
Jan 18, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Apple Ipod voice problem
hi
i had the same problem with my ipod and the volume limit control had been set to playback at low volume...if you have the ability to change settings try this ; when ipod switched on , go down to "settings" and click on this and then select "volume limit" ; click on this and then use the wheel to set the maximum volume you wish to use ( i set it at about 80/100 to ensure no distortion) hopefully this will solve your problem
Dec 25, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Philips GOGEAR SA6045 MP3 Player Logo
938 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
