Question about Garden
My homelite chiansaw HCS3335 runs fine for about five minutes and then just cuts out and will not start until it has cooled down what is the problem
    Sergeant:
  • 316 Answers
Hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, ``
Posted on Feb 20, 2012
  • 211 Answers
SOURCE: Loss spark
Hi
You need to replace the coil but first try to change the sparkplug and see what is happening.
best regards savumihai71
Posted on Jan 14, 2009
  • 97 Answers
SOURCE: runs fine for first 5 minutes then cuts out.
Most times that would be a sign of a coil going bad.When it stops quickly check for spark,if there is none you have a bad coil.
Posted on Mar 15, 2009
  • 384 Answers
SOURCE: runs about 10 minutes 7 cuts off. can't restart
Plan your beer breaks every 10 minutes and enjoy the time off. Also check your fuel mix, the engine is running hot, replace fuel mixture with proper oil mix.
Posted on Jul 15, 2009
  • 168 Answers
SOURCE: runs well untill it gets hot. then cuts out
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Posted on Aug 02, 2009
dontbother10
  • 2220 Answers
SOURCE: Homelite chain saw quits in 15 minutes
Why are you not standing on the help desk where you purchased this? If it starts to sputter then dies It is probably a plugged fuel tank vent. When it begins to act up roll the saw so the fuel cap is up right and loosen it a little. If it smooths out and runs correctly you just vented the tank and that is where the problem lies. If it suddenly stops running with no warning it is most likely an electrical problem. If you repair either of these problems it may void your warranty. Why not make Homelite repair or replace it? If offered a refund I would not purchase any product by the same manufacturer. At best their quality control is lacking. HTH
Lou
Posted on Nov 23, 2009
Atv trouble shooting
poss overheating--carb needs rebuild--or need tune up
Jul 14, 2017 | ATVs
My chainsaw poulan p3314 will run fine for about five minutes, then cuts out and wont start until it cools down....???
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
Sep 16, 2013 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Starts and runs fine, about five minutes then sputters and dies. will not restart until cooled
do cold comp. test if below90psi remove muffler and inspect piston cyl. wall for scroing
Oct 20, 2012 | Poulan 14" Chainsaw
My homelitechainsaw HCS 3335 runsfine for about 5 minutes then just cuts out and i cannot start it until it has cooled down what is the problem
hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a clogged vent, this is a small thing but a big problem,,hope this helps, 11
Feb 20, 2012 | Homelite Garden
Truck runs great but cuts out and starts back up five to ten mins later. I replaced the fuel pump and wireing in fuel tank.
I have heard that in some vehicles, when the coil warms up, it operates sporadically. When the engine dies and it cools back down it operates fine until it heats up again and fails. This could be your problem.
Aug 31, 2009 | 1994 GMC Suburban
Runs well untill it gets hot. then cuts out
Aug 02, 2009 | Garden
Dryer gets hot and shuts off after five minutes,
Check your vent tube to make sure it is clear. It is probably getting to hot because there is no ventilation to the outside. When you have the front off, check all the way from the lint filter to the outsid of the house.
Mar 23, 2009 | Frigidaire FEQ332E Electric Dryer
Loss spark
Hi
Jan 13, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Frigidaire built stacked washer and dryer
There is a thermal cut off on the motor. when it overheats it will trip and not start until the motor cools down. Replace the motor to solve the problem.
Jan 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
