Network Problem How can I know or set the IP that the canon ir 3100cn is using? Thanks in advance
  • 318 Answers
To set change your IP you press the star button,then you go to system settings,network settings,TCPIP settings,there you enter IP.
Posted on Oct 31, 2008
My canon image runner 4005 (ir 330-405f) was connected to a network while i was formating my syste. The ip got deleted in it. What should i do?
check with network administrator for new ip or goto network settings and fetch ip by using the machine and thats it.
Sep 18, 2011 | Canon imageRUNNER 400S Copier
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
How to know ip adress for Canon ir c6800
Network settings are in the additional functions> system settting > network settings. If your printing to the copier the ip address should be there in the network settings.
May 13, 2010 | Canon imageRUNNER C6800 Copier
How to know IP adress for Canon ir c6800
On the control Panel
Press Additional Functions Key.
Press Report Settings
Print List should be 2 rows of choices/ Select Network and print list. TCP/IP will be on the print out.
To Change the IP Address
Press System Settings
Press Network Settings
Select TCP/IP Settings
Enter New Address or turn DHCP on
Back out by using reset key on control Panel.
Be sure to re-Power the copier by turning off/on at the main power switch on the right side of machine or any setting will not take.
Mar 22, 2010 | Canon imageRUNNER C6800 Copier
Canon IR 210N Network Configuration
You need to turn off the copier, wait a few seconds, then turn it back on. Make sure to select the Printer I/F button and press the setup button on the touchscreen when it comes up. Voila! Network settings.
Now, I can't get it to actually work, but that's a different problem.
Feb 19, 2009 | Canon Office Equipment & Supplies
Canon imagerunner Ir c3200 total reset
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Jan 20, 2009 | Canon iRC3100 Printer
Ok. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
Nov 12, 2008 | Canon imageRUNNER C3200 Color Printer
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
902 people viewed this question
