Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Can a Model 3612C be connected to a router table
  • 2,176 Answers
It looks like it can BUT before trying where are you located and I will try and find a Makita Factory Branch in your area that can make that decision or if you want I have Makita Headquarters phone number also. Let me know. Dave
Posted on Dec 24, 2008
My makita 3612c router sounds bad and don't function well ,as can be heard in the video, I can see sparks coming from the brushes!!! Any idea about how to fix? What is the cause of such a problem
You probably have no brushes left running on the armature hence the big sparks and noise. The armature will be beyond repair Take to an appliance repair shop but I fear that it will be cheaper to junk it and get a new one.. My experience with Makita is that the brand is selective in the quality.
Apr 04, 2013 | Tools & Hardware - Others
How do you install a ridgid router to a craftsman router table?
Brenda, They are just saying that if the router is too big, it won't fit. The sub-base is the plastic, usually black, disc on the bottom of the router. This disc is about 6 inches in diameter and about 3/16 inches thick. It is usually held onto the base of the router with three screws. The base is the big aluminum piece about the size of half a loaf of bread that has the handles and into which the router main part (the motor) slides into. For most router tables, you mount a router base (with the sub-base removed) to the underside of the table with screws. The router table becomes a giant upside-down sub-base. If your base fits, and the screw holes line up, you are good to go. However, it is very helpful to have an extra router base (without handles) to leave permanently attached to your router table so that you can easily swap the router between the table and normal use. Good luck!
Jan 13, 2013 | Saws
Router supplied by AOL - DSL-2640R Firmware version V1.18 The router drops the Internet connection constantly.
Your router has small NAT table and it's easy to overflow, especially if P2P like torrent used. The only solution to prevent router to drop out connections is reset it periodically or install Router Comamander software (freeware version available). Router Commander prevents router from dropping connections using dynamic NAT table size control.
Dec 12, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a brocken swich on my router internally do u know were i will find a new one??
what is the brand and model number and give me the city and zip if in the US and I will try and find one locally for you.
Jan 18, 2010 | Makita 3612C Router
Manual Craftman professional router table model
I have a Craftsman professional router table, laminated model 26608. I can not find a parts manual for this item. I tried a number of way to find parts for this item. I believe this was made by Bosch. I can not purchase a Router table mounting plate for this item. it measures 7" x 8". with a center hole of 3". also 3" insert rings. Bosch and Sears makes items for a professional router but the center hole is 3 3/4 inches and the plate is a lot larger in width and length. I have gone to Bosch on the internet and came up with a model RA1171. This is a model like the one I purchased; however, they have changed the size of the adapter plate and the center rings. the model no. they show is 29LCN1428.
Dec 31, 2009 | Craftsman Milescraft 1207 Turnlock Wood...
My linksys connection sometimes shows that another wireless network by the name of "Green Table" is within range and my connection strength seems to become lower when the "Green Table network" appears. My...
I would go into your settings of your router and change your channel.  It sounds to me like you are getting outside interferance with another router on the same channel.  If you need more assistance, please let me know and I will help you as much as I can.
May 31, 2009 | Linksys Wireless-G WRT54GS Router...
I am having difficulty changing the cutting bit on a Makita 3620
If I understand this right you can't remove the bit from the collet. If this is true there might be dirt on the collet and you can try and blow it out with compressed air. What I would do if that doesn't help is support the collet nut allowing the bit to hang free and gently tap on the back of the bit and this will remove it. It is possible that you may have overtightened it or the bit has a burr on it. Good luck
Dec 31, 2008 | Makita 3612C Router
Powerless
I would first use compressed air and thoroughly blow thru the vents. Second I would take out the brushes they have a black cap over them and after removing wipe them off with a clean rag and reinstall. Look at the cord for cracks in outer jacket. Plug in and try again. If this doesn't work UNPLUG tool and turn collet nut by hand and connect again and retry. That is about the only things you can do safely. When storing sometimes dust and debris gets inside tool and can make the brushes loose contact with the armature
Sep 17, 2008 | Makita 3612C Router
Internet
Start from ground zero
1. Is everything Powered up?
2. Check you internet connection
a. Can you directly connect to the internet by connecting a computer to the device providing the internet?
If this is good, then do this for later. ( it may not be needed but is good to have)
go to 'Start' -> 'Run' ->CMD[Enter]
Now you have a DOS box.
here
type CD \[Enter]
type IPCONFIG /all > ipdata.txt[Enter]
exit[Enter]
This copies the working IP Config that may be needed later.
Now connect in this order Internet connection to WAN Connection of router
Then connect one of the the LAN Connections of the router to
the working computer.
Turn off everything for 15 min.
No I am not kidding. Technical reason: Clear the ARP Table back at the ISP.
Restart the router then the computer.
Still no internet?
More details will be needed.
Router Make and Model
Internet Connection Type
Computer Make, Model OS and Version.
Good Luck
Jan 02, 2008 | Zyxel Prestige 660H Router
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
51 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
