Fujitsu Plasmavision Red Green Blinking fault code
My Fujitsu Plasmavision P55XHA51A isn't working. Upon switching it on, the LED shows green for aprox 30 seconds and starts blinking the LED: Red Green (Nothing) repeatedly every three seconds. Does anyone know what this fault code means? Or even better, can anyone point me to a service manual for my model? It doesn't display any image during this process, nor will it respond to the remote control after the initial switch on. I have to power it down manually with the aux power switch (followed by disconnection from the mains). I have been looking around the web for info on the fault code so I can estimate the cost of repair. The former Fujitsu service shop in Perth has been very unhelpful so far in my contact with them.
5 Suggested Answers
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Posted on Feb 02, 2009
pilot210
  • 39 Answers
SOURCE: Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
Posted on May 19, 2009
romsky79
  • 822 Answers
SOURCE: Phillips 42pf5321d/37 No picture Error code D3V3
pls. check the power inverter.
Posted on Jun 28, 2009
I have a plasma tv FUJITSU PDS 6101 and when I turn it on, it turns off immediately and the red led is flashing. It happens every time I try to open it. Does anyone has servise book for this model?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Jan 02, 2016 | Fujitsu Plasmavision PDS-6101 61 in. HDTV...
Green led in ON but red led in blinking,after so many blinks of red led the both lights ,red and green,gone off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 15, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Green orange then red flashing 3 times light
Dec 04, 2014 | Televison & Video
Why is screen not working? Red and green light both blinking?
Sep 18, 2014 | Fujitsu Plasmavision P42VCA30EH 42 in....
Fujitsu Plasmavision P42VHA51WS. The on/standby LED flashes once red then twice green repeatedly. Can I reset this? Rob.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 10, 2014 | Televison & Video
P42VHA20WS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 18, 2014 | Fujitsu Plasmavision 42" TV
Sony CRT TV type:DRC-MF DR34M69, long time to ON, LED stand by blinking red and green, how to solved this problem? Thank You.
Feb 04, 2014 | Televison & Video
Flashing red and green power indicator light
Y-Sustain board and its drivers should be checked.
Jul 16, 2012 | Fujitsu Plasmavision 42" TV
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
