Question about Nokia 5220 XpressMusic Cellular Phone
Troubleshooting: it black out.. can't open
While It was being updated, i accidentally removed the connector. and when im trying to connect it again, it won't open. it just light then off again :(
  • Nokia Master
  • 2,148 Answers
The last thing you can fix it by yourself is to flash the phone.So, Click here1 if you want to do it by yourself.And here is your file Click here4.Or you can contact any mobile repairing shop.Good luck
Posted on Feb 21, 2012
I have a hunter 29185 remote control and the connector on the 9v battery broke off. Can it be repaired?
Yes... absolutely.
Your handy dandy electronics store... used to be Radio Shack..
That (real) old garage door opener in the bottom drawer...
any snap set that has the matching black/red connecter wires...
Red to red
black to black... a little heat shrink tube and some solder and you are back in business...
God luck.
Aug 19, 2016 | Hunter Fan Televison & Video
Can't connect to farmville. It comes in at first then freezes.
Try these troubleshooting techniques:
First of all update the browser
Update flash player
Update Display drivers
Remove unwanted tool-bars and plug-ins
Optimize Internet
If you are unable to perform above tasks then use a single utility tool like PCFresher that will not only fix windows errors but will also optimize Internet.
Apr 25, 2013 | HP Pavilion Computers & Internet
I am having trouble reconnecting the 4 connector FFC for my backlit keyboard.
Check the connection on the motherboard a little closer. There should be an unlockable part in the connector which you can slide back and forth in order to remove/fix the cable.
Jan 13, 2013 | Computers & Internet
Toshiba c655d battery not charge
The motherboard maybe damaged beyond repair because you only see broken tracks on the top layer and most likely other circuit tracks are broken in the other layers on the motherboard.
Oct 15, 2012 | Toshiba Computers & Internet
I don't have record vedeo in my iphone3 8gb I can just take photo coud u help me please
The iPhone 3G did not initially come out with video recording capabilities, but the functionality was added through a software update. If you connect the phone to iTunes, and click on Check for Update, you can update it to the latest firmware, and then you will gain recording functionality. To use it, open the camera app and press the switch in the bottom right of the screen to switch to video recording.
Jun 21, 2012 | Apple iPhone 3G Black Smartphone
My nokia c3 cell phone has a camara malfunction, it does not open the camera device on my phone and my phone freezes when trying to process the camera request
For Camera hang ups or frozen if using it, this problem can be fix by firmware restoring, flashing or updating. So try to do a software repair first before proceeding to hardware troubleshooting.
If the camera doesn't turns on or having problem like showing empty or black screen, this is due to problem in hardware.
For instructions to update firmware, please check following link.
Nokia C3 Software/Firmware update
for more help about nokia c3 troubleshooting, click here
Sep 26, 2011 | Nokia C3 Cell Phone
I have a 1992 dodge dakota 3.9l v6 when im driving the motor will just cut out. sometimes it will start right back up and sometimes it will take like 15 to 20 min before it starts back up. no check engine...
One way to confirm if it's a spark problem or fuel delivery problem is, when it quits and won't start, remove air intake hose at throttle body opening and spray some WD-40 ( 2-3 sec. ) into throttle body, then try to start. If it fires up momentarily then stalls again, have fuel pressure tested. The WD-40 acts like quick start and if that fires the engine over, then you have spark, but not enough or any fuel.
If that doesn't help, no start at all even with WD-40 sprayed in throttle body, then I'd think real serious about changing the hall effect pick-up ( pick-up coil) in distributor, if you have that style distributor. It is located under distributor cap below rotor, it looks like a round black plate in shape with wiring and connector at end of it. Remove cap, remove rotor, and lift it out, unplug from connector. Replace it in same position, then re-install rotor, then cap. They were a pretty common problem in earlier years. Engine would just quit anytime after it was warmed up, then sit for 15-20 minutes, then restart and go for a while and do it again.
Sep 03, 2011 | 1992 Dodge Dakota
Im been trying to download version 1.10 update software for Call Of Duty:Black Ops, and it simply wont let me download it, it goes until 6% downloaded and it fails. My error code is 80710723 and i've...
80710723 Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
You really might want to try creating the connections again on your PS3 system on the same modem/router you are using.
Just re-configure you connection settings and see if that helps.
Jul 08, 2011 | Sony Playstation 3 (PS3) Console
Bluetooth device not working and not detected in device manager
Good day. In regards to your issue when it comes to your bluetooth device you can try the following steps. Usually these will resolve your issue
1. If your Bluetooth device uses batteries, make sure that your batteries are charged. 2. If your Bluetooth device uses a transceiver that connects to your computer through a USB port, try connecting the transceiver to another USB port on your computer. 3. If there are multiple Bluetooth devices connected to your computer, temporarily remove the devices that you are not troubleshooting. If there are additional USB devices, try removing any USB devices that you do not have to have installed during the troubleshooting process. If you h have multiple devices that are connected by using USB, this can interfere with a Bluetooth transceiver. 4. Verify that the Bluetooth device that you are troubleshooting is powered on and that it is enabled.
If these steps didn't resolve your concern, you can try to update your windows version like installing updates that can be found on the microsoft.com website or go to http://update.microsoft.com. You also have the option to contact HP for them to help you with issue but most probably they'll be charging you for this specific problem. Hope this information will be helpful in resolving your concern. Have a great day and thanks for using Fixya.
Jun 25, 2011 | HP Pavilion DV9500T 17" Notebook Laptop PC...
Pleas how to repair my nokia 3110c light problem
hi,
there are several reasons why there is no light in your lcd screen.
1) you accidentally turn off its lcd backights if your unit has that features. check on it on display settings of your phone.
2) probably your phone experience accidental impact and that causes lcd flex connector to get loose and causes no light for the display.
3) busted lcd backlight or open line connection to backlights.
I recommend not to open your phone since it is very tricky to open it and there's a great chance of damaging the LCD and also your unit is still in warranty and if the warranty sticker is broken, your warranty is void. instead have it repaired to your phone dealer or provider and that saves you from trouble.
but if you really to gamble and give it a try (Don't do this if your not sure what your doing!), you can fix it yourself if the problem is on no. 2 (loose connector). open your phone slowly (since delicate parts inside and remember its part placements) using t6 or t7 screws and locate the lcd flex connector (usually behind the LCD) that connects the lcd to the main board. remove it slowly not to damage it and look for abnormalities, if none, then put it back securely and assemble your unit. then give it a try...
Good Luck!
Don't forget to rate me OK! Thanks...
Hope i helped you...
bst rgrds,
John
Jan 06, 2011 | Cell Phones
Nokia 5220 XpressMusic Cellular Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
