Question about Samson Auro D415 - 2-Way Active Speaker Speaker Enclosure
My Samson Auro D415 peak light stays on, and i get no sound when powered on
  • Mauro Gomez
    Mauro Gomez May 23, 2016
    Hi, I have the same problem... did you find a solution??
2 Suggested Answers
SOURCE: hey, i bought a new
I have a 412 speaker that works good at low volume with simlple set up when key boards turn up on mixing board the red peak light comes on and speaker shuts down i think its a protective shut of for overload but very easily triggered have to work with material too find a solution can any one confirm this shut off phenomena
Posted on Jan 06, 2012
Samson Resolv 40A,no sound, power light on cables good.
Your best bet is to take them to an authorized repair center. You may also want to talk to Samson directly. Here is their support link-
Support SamsonTech
Mar 19, 2013 | Samson Resolv 40A Monitor Speakers
Hum from Samson XM610 Powered mixer
hi, my samson xm610 have a problem even i tern off the voluem of each chanel still have a sounds be fore is not just like that.. can you help me
Aug 27, 2012 | Samson Xm610 Powered Mixer
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
Power light comes on but individual mute and channel lights are not working . No sound outputting.
This is likely a power supply failure within the unit. Needs to go to a shop for repair.
Sep 20, 2011 | Samson S Phone 4 Channel Headphone...
Hi, I have one Samson Auro d412a active speaker plugged into the output channel of a 12 channel passive mixing board. When I sing into the mic, the speaker shuts down and the red light on the back...
If you read the TRUE specs on this speaker it is really a 200 Watt RMS unit. Make sure you are using balanced lines to the speaker XLR or TRS cables. The mixer should NOT be a passive mixer as these do NOT generate true balanced lines. Make sure the mic can't "hear" the speaker or you may be getting supersonic feedback that is above your hearing range that saturates the amp. If *********** can't stand to be ain a 15 foot square room with teh level you are generating, it is TOO loud for this unit to handle.
Aug 01, 2011 | Samson Auro D412A Speaker PA Active
Played samson 412 aura speakers for about 6 hours today with the volume at 1/4 of the way turned up.. the speakers became very hot and turned off by them selves.. I have them mounted on stands in a corner...
The volume setting on the speakers has LITTLE to do with how hard you are driving them. Your source might be extra hot and overdriving them. Read the specs on the speakers and use a sound meter to check your level. The speakers, being only 12 inch, should fill a room 20 foot by 20 foot to about 95 to 100 Db which you are only allowed 2 hours in MAX to prevent hearing loss. At 6 hours you should keep it down to 85 Db SPL. I know several deaf musicians that were exposed to high sound levels in rock bands... a deaf musician is kind of washed up.
Jul 03, 2011 | Samson Auro D412 2Way Active Speaker
What do I need to hook up to our church pa system
Connection all depends on what type PA system you have. Here are the rules: Power this device from the SAME receptacle your mixer is powered by, even if it means running an extension cord. Use ONLY a balanced line from the mixer... either TRS cable or XLR cable.
Apr 02, 2011 | Samson Auro D412A Speaker PA Active
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
HOW DO YOU TURN DOWN THE HISSING NOISE
You can cut the treble gain some BUT most importantly is to send adequate signal to this speaker so volume level does not have to be set high when sending LINE LEVEL signals to it. Hissing noise is a product of the statistical noise that occurs in electronics. Running any device at high gain invariably brings up the hiss level. Managing thee signal levels is the responsibility of the sound engineer.
ALSO feed ALL interconnected equipment from the same receptacle or power source, even if it means running a power cable to a mixer alongside the snake. ALWAYS USE BALANCED audio cables whenever possible.
Dec 24, 2010 | Samson Auro D415 - 2-Way Active Speaker...
Samson Auro D415 - 2-Way Active Speaker Speaker Enclosure Logo
198 people viewed this question
Top Samson Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
ray gallant
Are you a Samson Music Expert? Answer questions, earn points and help others
