Question about Garden
Wiring diagram for Honda 5.5hp electric start engine
We have a 5.5hp Honda engine, approx 2002 which powers our Club 7 1/4 gauge Locomotive, at present the whole loco chasis etc is being overhauled except the engine which is OK. The existing ignition key start box which is separate was removed (not by me) as the key had been lost & it was started by putting a screw driver in to it. A new one was purchased which is internally different to the old one & clearly does not start the engine, at this stage the people doing it up gave up & involved me. Having had a good look at it the new one does not have as many components inside it although the actual (aluminuim cased black box) seems to be more sofisticated. Its the belt driven, drive to a hydralic pump & drives our clubs 7 1/4 gauge rail loco which provides rides for kids & families at our local country park.I would really appreciate any help which you can give me, I am a retired electrical engineer whom worked in the supply industry on pylons & their associated grid txs, circuit breakers etc. So l do understand a little bit about electrics. Many thanks Maurice.Bennett.
SOURCE: Electric Pressure Washer
Hi Your problem is your unloader pressure valve switch.It is a cylinder that moves up & down inside a housing,. activaded by water pressure.Inside the cavity of the housing is dirt on the wall of it.Thats your problem.Once you clean the cylinder wall & apply some water grease ,problem gone.Your problem is not the switch.
Posted on Feb 14, 2008
  • 651 Answers
SOURCE: 1999 Silverado, 5.3 engine, 4 wheel drive, battery good, no juice
make sure the battery cables are clean and tight. check wires on alternater, make sure tight connection. are you sure battery is good?
Posted on Dec 01, 2008
picatudo
  • 239 Answers
SOURCE: NO PRESSURE FOR BLACK AND DECKER PW1400
the pump went bad
Posted on Dec 28, 2008
SOURCE: no electrical power at all - turn key - nothing -won't start
Check fuse link.
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: Can't start the Honda GX160 5.5 HP Electric motor
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Posted on Apr 27, 2009
I keep blowing my 30amp main fuse on my 2002 Honda shadow sprite vt1100c.. when i start it ,it runs for a sec then power down
There is possibly a short to the frame. Look under the seat. Since it starts first, the short could be to an item that gets power after the ignition is on, such as a gauge, light, tach.. anything electric that isn't indicating before starting the machine.
You could run an ohmmeter from gauges to the frame to see where the short is. Leave the ignition off, or remove the ground wire from the battery before this test or you could damage the ohmmeter.
Touch wires after this happens; if a 30 amp fuse is blown, something is getting hot. (You could burn your finger.) Don't bypass the fuse; you'll burn up the wiring and possibly the bike.
Oct 13, 2016 | Honda Motorcycles
Honda 20hp wiring diagram
are you trying to install a key switch assembly i can help you just indicate color of wires your dealing with,honda tech 30 years
Aug 25, 2014 | Honda Engine 20hp Horizontal Tapered Shaft...
2002 Honda Cd 125T wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2002 Honda Cd 125T wiring diagram Google Search
Honda Motorcycle Wiring Diagrams
Honda CB125S Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Mar 15, 2014 | 2002 Honda Cd 125T
Locate Oil pressure sensor on 95 ford club wagon
assuming you have oil in the engine check close to the oil filter for a single wire sensor... but you need to check the gauge first. just ground the wire for the sending unit against the block. the gauge should peg. then go to harbor freight and get a pressure checker for 20 bucks and remove said sensor, screw in tester, start and watch. if all is good, replace sensor
Dec 28, 2013 | Worldwide 1995 Ford E150 Econoline Club...
Electrical problem
Have the engine bulkhead connector checked for water intrusion or loosened connections.
Aug 08, 2012 | 2003 Ford Mondeo
I need to know what gauge wires black and red for battery to generator
This is what I assume is for the starter motor for the generator. I would use for this a #8 welding wire style cable. This will supply enough power for starting.
Jan 30, 2011 | Honda Mmd 5000 Watt Electric Start...
98 acura integra.....not getting spark to coils.....need help....car shut off on me while driving....will not start back up.....engine cranks but wont start....
is there power at the coil's electrical connector(key must be set to ON? Is some of your warning lights not lit(that normally light-up when key is on) such as airbag, abs, engine, battery etc??? If you answer yes to any of this, your ignition switch has failed. Acura/Honda models 97-02 have a recall on this in 2002 approx 1.5million vehicles affected. Symtoms include, intermitted speedometer/tach fluctuating to zero while car is in motion, intermitted stalling or no start(symtoms increase in hotter weather). The electrical contacts on these ignition switches are faulty causing shorts and archs within. Therefore power supply to vital engine electrical components are cut off. If this is the case, call your local Acura/Honda dealer with your vin# at hand, your vehicle may qualify for a free repair. Hopefully this helps....please rate thanks!!
Aug 18, 2009 | 1994 Acura Integra
Need electrical diagram
here is the diagram
http://i270.photobucket.com/albums/jj95/sunwall69/Honda92-01CR250_Wiring_1.png
and the actual mechanic service manual if you need it.
http://www.tradebit.com/filedetail.php/4593707-honda-cr-250-r-2002-2003-service-repair
Jul 16, 2009 | 2002 Honda CR 250 R
Garden Logo
383 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
