Question about Ricoh Office Equipment & Supplies
Rico aficio 1224 with error sc305
Ajusting colour doesnt stop
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
munybuny
  • 14 Answers
SOURCE: Error code SC305 for copier ricoh aficio 1224c
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T
Posted on Jun 22, 2008
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
  • 30 Answers
SOURCE: PHOTOCONDUCTOR UNIT FOR RICO AFICIO 2015
it dosnt use a pcu it as a drum and developer part number for drum is B0399510 dev is B1219645
Posted on Jul 08, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Please show me how can I unlock the error code
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Posted on Dec 08, 2009
Sc305 1075 aficio
SC305. Occurs after replacing charge corona unit.
trnsp.gifAnswer [Cause]
PCU-side quenching lamp has come loose from bracket.
[Action]
Return quenching lamp to correct position.
Aug 20, 2011 | Office Equipment & Supplies
I have a ricoh 1224, and is displaying a 'functional problems' notice. Is there a solution to solve this?
What is the exact error code that you are getting? There should be a code displayed on the screen, starting with "SC" and ending with three numbers. Those three numbers will determine what the exact problem is. Depending on the code, it may be something easily fixable, but if it requires replacement of any parts, you may be out of luck -- the 1224 is an old printer, and it may be difficult to find new parts for it.
Aug 18, 2011 | Ricoh Aficio 450 Copier
What is SC305 Error Message - Ricoh 1232C On
I worked on this same code just the other day for a customer. This SC305 code means the charge corona cleaner is not working properly. The charge corona is located behind the large front door, towards the bottom and just left of center. It has a small thumb screw and a white cord with an end on it like a telephone cord. You can try removing the assembly and blow it out carefully with canned air. Be careful about the very thin hairlike wire in the shell. You can also remove the end of the unit and check that the motor is not gummed up. If it is just put a little light oil on it. Just cycle the power off then on again to reset and try.
Usually once they get repositioned properly they will work fine. Sometimes I have replaced the unit with one from a parts machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 27, 2010 | Ricoh Aficio 1232C Color Copier
I am getting SC412 on my Ricoh Aficio 1224C, how do I fix it, and what is it?
sc412 on a 1224 is 2nd transfer (paper transfer) disconnection (+).
The possible causes are:
- The right cover is open
- The transfer roller contact mechanism is broken
- A bad high voltage supply board
- A bad BICU-to-HVSB cable
Parts for the 1224 will be obsolete soon if they are not already, so you're probably better off upgrading to a newer copier if closing that right cover and resetting the machine doesn't fix it.
May 18, 2010 | Ricoh Aficio CL7000 Laser Printer
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
I can get you one, but they are expensive.
Nov 24, 2008 | Ricoh Aficio 2015 Copier
Richo aficio error sc305
Hi All,
Charge AC Bias Error
Check connector for Magenta PCU
Replace the Magenta PCU
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Dave T
Jun 18, 2008 | Office Equipment & Supplies
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
